BigJimnyMeet 2024
× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Scratch head (Gen 4 Owner manual)
  • Andy2640
  • Visitor
  • Visitor
03 May 2019 05:35 #207152 by Andy2640
Scratch head (Gen 4 Owner manual) was created by Andy2640
Morning all,
On page 3-16, the topic is "changing from 2H to 4H" - Its states "Do not shift the transfer lever without depressing the accelerator pedal" EHH????
It also goes on to say that the locking air hubs cannot be activated if the vehicle is slowing down, but then says it can be done at standstill. EHH?
Any help would be appreciated.
03 May 2019 05:58 #207159 by stiffsteve204me
The first part, I would assume, is a misprint, Andy. Surely, it should read brake pedal?:huh:
Where are you seeing this?:
"It also goes on to say that the locking air hubs cannot be activated if the vehicle is slowing down, but then says it can be done at standstill."
Full marks to you for reading the manual, by the way. :laugh:
Steve.
“He that strikes the venison first shall be the lord o' the feast.” — Shakespeare, King Lear.
  • Andy2640
  • Visitor
  • Visitor
03 May 2019 06:07 - 03 May 2019 06:08 #207161 by Andy2640
Replied by Andy2640 on topic Scratch head (Gen 4 Owner manual)
stiffsteve204me wrote: The first part, I would assume, is a misprint, Andy. Surely, it should read brake pedal?:huh:
Hhaha, thanks Steve. All this is on page - 3-16.
It makes me laugh, because next to most this 4H to 4L thing, there are warnings saying "FAILURE TO FOLLOW WILL RESULT IN SERIOUS MALFUNCTION" Intimidating bloody manual so it is ;-)
Ok, the manual actually says this; " The air locking hubs are activated by the vacuum of the engine and changed to shift the front wheel drive. The air locking hubs are not shifted when the engine is stopping" / - So are they saying that decelerating will not activate the air hubs? Hence there instruction to be accelerating??
Mhhhhhh Pondering's..........
Steve.
Last edit: 03 May 2019 06:08 by Andy2640.
03 May 2019 06:23 #207167 by stiffsteve204me
Steve.
Ah! Now, I read that as saying that the engine needs to be running for the air hubs to operate.
I think that it should read "The air locking hubs are not shifted when the engine is stopped"
Steve.
The following user(s) said Thank You: Andy2640
  • Lambert's Avatar
03 May 2019 06:26 #207169 by Lambert
I think it means that the engine has to be running to generate the vacuum. So it won't activate the hubs when switched off. I would also expect that charging between ratios is done while stationary and the brake applied and clutch down. But it should be able to switch from 4x2 and 4x4 high on the move.
03 May 2019 06:27 #207170 by Bill Portland
The translation of the manual is quite good, but I noticed it get worse further on.
  • Andy2640
  • Visitor
  • Visitor
03 May 2019 06:30 #207171 by Andy2640
Replied by Andy2640 on topic Re:Scratch head (Gen 4 Owner manual)
Mhhhh, thanks for the perspectives, this is a funny one tho hay? "Do not shift the transfer lever without depressing the accelerator pedal"
It says nothing about depressing the clutc when switching from 2H/4H/4L??
  • Lambert's Avatar
03 May 2019 06:32 #207172 by Lambert
That could have changed but on the gen3 it's a thing.
  • Andy2640
  • Visitor
  • Visitor
03 May 2019 06:34 - 03 May 2019 06:35 #207173 by Andy2640
Lambert wrote: That could have changed but on the gen3 it's a thing.
So is the consensus, that we should depress the clutch when switching from all transfer modes?
EDIT: Better safe than sorry I suppose.
Last edit: 03 May 2019 06:35 by Andy2640.
  • Lambert's Avatar
03 May 2019 06:45 #207174 by Lambert
I would. Like you say being cautious is not a bad thing.
  • Andy2640
  • Visitor
  • Visitor
03 May 2019 06:48 #207175 by Andy2640
Lambert wrote: I would. Like you say being cautious is not a bad thing.
I follow your wise and mystical giuidance Lord Lambert :-) On another note, to my monkey mechanic mind, "air hubs" sound like something that could go very wrong, very easily. Hope I am wrong though...ekk!
  • Lambert's Avatar
03 May 2019 06:55 #207176 by Lambert
Mine didn't make it to year 4. Since then I have had avm manual ones. Bit more effort but way more reliable and versatile. They allow me to run on the road in 4x2lo which is great for towing and manoeuvring trailers. It is possible to do this electronically on the gen3 as well as mechanically so I suspect that it is a modification in development for the gen4.
Powered by Kunena Forum
