BigJimnyMeet 2024
Gear stick play?
- Mraz
- Visitor
07 Nov 2017 11:57 #185942
by Mraz
Gear stick play? was created by Mraz
Hi guys.
So, my gear stick is all over the place and shifting to 2nd gear is somewhat harder than others. I took a look and there's a noticable gap between the ball on the end of the gear stick and the part it connects to. Logic says there should be some sort of bushing between them, right?
Can anyone help me with this?
- Thank you received: 1761
07 Nov 2017 13:15 #185951
Replied by Lambert on topic Gear stick play?
I have never had one apart but there's some sort of bush sleeve thing that fails or drops off or something. There's a few threads on it here and there.
- Mraz
- Visitor
07 Nov 2017 13:29 #185952
by Mraz
Replied by Mraz on topic Gear stick play?
I've read a few thhreads about it but there's no pics of the actual bushing. I was thinking of making a sleeve out of bronze that fits between the ball and the lever but I'm not sure should the ball hold the lever in place (so it doesnt move up and down) or would it be fine just to make a bush that removes the play without firmly holding anything.
07 Nov 2017 13:35 #185954
Err dunno. Anyone else care to join in?
- Thank you received: 653
07 Nov 2017 17:03 #185960
Replied by jackonlyjack on topic Gear stick play?
The last post by Leeds83 has the part number and image of the bush
www.bigjimny.com/index.php/forum?view=topic&catid=7&id=62654
Jack
Jack
- Mraz
- Visitor
07 Nov 2017 17:44 #185964
by Mraz
Maybe I'm looking at this the wrong way but my gearbox is not the one on the diagram. There should be a ring with three screws and mine doesn't have that.
As far as I understand I have a "R72" gearbox? '06 VVT manual
07 Nov 2017 17:51 #185965
Replied by Riccy on topic Gear stick play?
Your right, that link refers to the earlier R7ME gearbox,
You should have a white plastic bushing on the end of the stick shaft. it clips onto the ball end to square it off. Would be really sloppy without it.
Martin (the forum main man) can get suzuki genuine parts so should be able to source one for you Cant help with a part number tho
07 Nov 2017 17:54 #185966
P.S. if you make a bush i would use a rigid plastic rather than bronze (which will transmit noise something rotten!)
07 Nov 2017 17:56 #185967
PP.S...
The picture of your gearbox connection looks wrong. The collar is damaged and is inside the body when it should be below? why is it sitting so high?
- Mraz
- Visitor
07 Nov 2017 18:08 - 07 Nov 2017 18:38 #185969
by Mraz
I assume it was damaged when it was removed and I honestly have no idea why it protrudes inside the body. I got the car year ago and drive it like it is. No leaks, no grinding noise, all gears work fine and are easy to engage (second is a bit harder), 4H/4L works fine.
EDIT: Just took a look under the car and nothing seem out of place or bent.
Last edit: 07 Nov 2017 18:38 by Mraz.
07 Nov 2017 18:53 #185976
my bad, i have a 2" body lift, so mine is lower!
- Mraz
- Visitor
07 Nov 2017 19:03 #185977
by Mraz
You almost gave me a heart attack!
Time to create page: 0.134 seconds
