BigJimnyMeet 2024
× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Oooh, I do like a nice rack! ;)
  • Nissan300
  • Visitor
  • Visitor
03 Jun 2017 16:11 #181717 by Nissan300
Replied by Nissan300 on topic Re:Oooh, I do like a nice rack! ;)
I need to stop reading all these posts as they always end up costing m w money. Good work looks really good and practical to.
Sent from my SM-G935F using Tapatalk
  • Riccy
  • Riccy's Avatar
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
03 Jun 2017 17:08 #181723 by Riccy
S200KYS wrote: Thanks Riccy ;)
Ordered the switches last night -
Light Bar, Back Lights, Two Wheel Drive Low! ;) and, errr, a winch switch? Ah well, you never know... :evil:
Out of interest - where are you thinking of mounting them switches? Its pretty easy to get wiring to anywhere, but not much available to put them in.
  • X8GGY
  • X8GGY's Avatar Topic Author
  • Platinum Member
  • Platinum Member
  • but currently AWOL
05 Jun 2017 19:37 - 05 Jun 2017 19:38 #181772 by X8GGY
Switches are (hopefully) going where the old four wheel drive selection buttons were, as I've replaced the VVT solenoid transfer box with an older stick selection box...
Meanwhile, the snorkel was shipped from Italy today :woohoo: !
Last edit: 05 Jun 2017 19:38 by X8GGY.
  • X8GGY
  • Platinum Member
  • Platinum Member
05 Jun 2017 19:44 #181773 by X8GGY
or I could always throw the stereo away again?... ;)
  • X8GGY
  • Platinum Member
  • Platinum Member
14 Jun 2017 15:47 #182012 by X8GGY
Light wiring finished (on the roof rack at least) ;)
Soldering iron, heat gun for the shrink tubes...
Up from the aerial hole and along the front mesh of the roof rack and into the front light bar...
And then round the back for the two reverse / work lights
Testing!
Just need to sort the dash wiring and switches out some time then? ;)
  • X8GGY
  • Platinum Member
  • Platinum Member
21 Jun 2017 13:41 - 21 Jun 2017 13:43 #182240 by X8GGY
Finished off the wiring today...
Take centre of dash out...
Cut a neat rectangular hole in it... ;)
Add switches B)
Wire it all up (not as neat as Riccy's !)
The two spare pins in the photo are for the two-wheel-drive-low switch - see the coil of wire in the last photo ;)
Replace dash'!
Then think about it... hmmm... wouldn't it be nice if the rooftop LED bar also came on with main beam, as well as the manual dash switch? Be good for flashing people...
Wire relay up "the wrong way" ;)
SO... I've got a fuse and two positive wires going to PIN 30 and PIN 86 (30 is normally the 'feed' and 86 is the 'switch' - but Suzuki headlights are weird*)
PIN 87 goes to the lightbar# to power it
PIN 85 is the earth, usually!, so we need to connect this to the wire on the headlights which is normally live when the ignition is on but drops to earth when main beam is on (I told you Suzuki headlights are weird*)
This one -
*So, when the ignition comes on, all THREE terminals on the back of the Jimny headlight are ALL LIVE, when we switch the headlights on, one wire drops to earth to make the circuit, and then when we go to mainbeam (or flash) a different wire drops to earth, it's this one we need to switch the relay over... This works as the two live terminals (Feed and Switch) are always live (through the inline fuse) but the relay won't switch on as it has no Earth... UNTIL, the headlight wire drops to Earth on mainbeam, then the relay will trigger/switch on and light the lightbar (or spots)...
# - my wire goes to the 'OUT' terminal on the back of the manual dash switch, i.e. the LED lightbar either gets it's power from me switching it on from the dash switch, or if I switch to main beam or flash the headlights, the relay triggers and feeds the LED lightbar... hope that makes sense?
I then tidied all the wires in the engine bay and under the dashboard...
The loop in the footwell will be going down to the transfer box and in series with the four wheel drive switch on it, so that I can "fool" the ECU, it won't think I'm in four wheel drive, the vacuum hubs will switch off, and I'll therefore have two-wheel-drive-low to the rear axle...
DONE! B) A project finished for a change... not that they are ever really "finished" ;)
Last edit: 21 Jun 2017 13:43 by X8GGY.
  • Riccy
  • Riccy's Avatar
  • Banned
  • Banned
21 Jun 2017 18:48 #182242 by Riccy
Looks good :-) surprised they fit there so neatly.
I found my switches work upside down to a house light switch (look like they are switched on but are actually off). This may be the specific switches i have, or my mates wiring! Not got it finished yet so only my ARB stuff and the USB socket/volmeter works so far.
  • X8GGY
  • Platinum Member
  • Platinum Member
21 Jun 2017 18:55 #182244 by X8GGY
Weird, I thought it was me! I wired everything up to the enclosed schematics of how the switches worked... and then found the roof lights were on when I thought they were off, and vicky-versa... So, I took the rockers off and rotated the switch housings by ninety degrees and then put the rocker switch covers back on t'other way! :lol: All ok now ;)
Thinking about it the winch was reversed too, so I just swapped the two wires over to give me the correct IN and OUT...
  • Riccy
  • Riccy's Avatar
  • Banned
  • Banned
22 Jun 2017 06:11 #182247 by Riccy
I think they are supposed to be like that. The ARB air switches all are the same, and they are using the wiring harness they came with. What does your ARB switch in the blue jimny do?
We ended up living with it the other way round. the indicator lights didnt work properly with the rockers turned around. Dash illumination works ok tho.
also cheers for the above description of how the headlights work, that would have confused me for ages (electrician's dont use negative/neutral switching normally)
  • X8GGY
  • Platinum Member
  • Platinum Member
22 Jun 2017 10:22 #182251 by X8GGY
ARB Switch in the Blue Jimny works fine... out of the box as far as I can remember? And the air actuator switch too...
LOL :lol: Yes, worked out the headlights years ago on various Vitaras ;)
Just hope the description is clear enough for everyone to understand?...
  • florinelu07
  • Visitor
  • Visitor
09 Nov 2017 10:23 #186027 by florinelu07
Replied by florinelu07 on topic Oooh, I do like a nice rack! ;)
hi,
from where did you get the switches?
  • X8GGY
  • Platinum Member
  • Platinum Member
09 Nov 2017 10:40 #186029 by X8GGY
florinelu07 wrote: hi,
Good old eBay ;)
Time to create page: 0.264 seconds
Powered by Kunena Forum
