Manual Hubs
I can see where you are coming from, but I think there are a couple of flaws in your logic.
Firstly the shaft and hub aren't spinning at massively different speeds are they? Unless you are wheel-spinning everywhere, for the majority of the time they are actually spinning at the same speed, so nothing is wearing against anything.
Secondly, when you are in normal 2wd mode the shaft is stationary and the hub is spinning around it very quickly. Is this not what you are describing, but in reverse?
Helijohn puts it quite well. If it works one way round, why not the other?
The amount one shaft spins compared to the other can vary too according to how much drag there is, which is varied by a number of things, such as how much grease is in each CV, the resistance of the shaft in the oil seal or the bush the CV runs on in the knuckle. So one shaft might spin much more than the other allowed by the diff and hey the differential in speed is greater.
The diff will allow the drive to follow the path of least resistance, so if one shaft has less resistance on it from the CV, the axle oil seal and the rubber bush in the knuckle, the drive will spin out through that shaft more than the other or only through that shaft in a worse case scenario.
Trust me on this guys. It's been proven in practice. It happens and I read of it happening to someone only in the last week or so. If I can find where I shall point you in the direction of it if it was online.
Call me fool-hardy but I'm going to carry on using it in 2low so I can see for myself.
- jonesyba420
- Visitor
what actually happens in the transfer box when you select 4wd? (Manual syatem with vacum hubs)
I thought it just sends a signal telling the system to lock the hubs to the drive shafts, or does it also do something else?
youd think you would hear grinding etc if it was causing problems.
- Thank you received: 260
I trust you - I just don't get it! It is academic for me anyway.
- jonesyba420
- Visitor
im sure busta has had it a while and uses it regulaly with no problems.
Firstly, the actual movement of the lever engages drive to the front propshaft. This in turn drives the diff and then halfshafts, sending drive to the centre of the hubs.
Secondly it triggers a switch which completes an electrical circuit which triggers the vacuum system to engage the front hubs. This now allows the drive to be transmitted to the wheels.
Both of these things need to happen for drive to reach the front wheels.
Switching the '2low' switch simply breaks the circuit to the vacuum system, making it think you have moved the lever back to the 2hi position and thus disengages the front hubs. At this point everything up to the front hubs is still being driven.
- jonesyba420
- Visitor
