Need guidance on trailer woes
- Thank you received: 260
- Thank you received: 584
A new hub is
The bearings are replaceable, they are lifetime (of a Mayfly) sealed races on the small trailers, taper rollers on the bigger ones.
If there was a castellated nut & splitpin they are tapered, yours looks like sealed plain bearings to me.
I hope you unscrewed a locking nut & washer off that spindle!
Anyway, the hub pulls off (use a hub puller to press the centre spindle down and lift the hub off.) I wouldn't hammer it off, as I'm not sure that anything holds the axle in except maybe glue on the rubber.
If it is the small Erde type the races are 6202-2RS on the outside and 6004-2RS on the inside. 2RS means rubber seals both sides, they are a couple of pounds each.
Get a new wheel stud, and weld it in place if the flange is steel.
You could take the rubber seal of the inside of the new bearings, and fit a grease nipple to the hub between the bearings, then keep greasing them.
I'd get the bearings out and check the numbers stamped on them, or check the measurements
6202 is 35mm OD 15mm bore and 11mm wide
6004 is 42mm OD 20mm bore and 12mm wide
The spindle will have 2 diameters and taper between them.
Pull yours off and see what the axle is.
facade wrote: A quick blast on eBay "trailer hub stud" shows some reasonably priced hubs complete that fit 1" dia stub axles.
I can't get it off to see. I thought it would be held on like a front wheel bearing but not so apparently. I looked at the prices and couldn't decide if I should scrap it.
It must have a bearing seized on the spindle.
What was on the thread on the spindle? I'd expect a washer with a diameter of the inner race under a nylock nut.
facade wrote: If there was a castellated nut & splitpin they are tapered, yours looks like sealed plain bearings to me.
Nope, not castellated. I thought unscrew the nut and it'd fall off. I was wrong.
What locknut hehehehe. There was just a plain nut. But I did take it off and the washer and try hammering the hub off. Was past caring as the stud hole was half gone!
When the deluge stops I'll get a puller on it and try again then we'll know more. I am more concerned about the missing lug but I guess plenty of trailers are in bin bottom condition.
The flange is alloy and I don't do alloy welding. I even thought of making a steel spacer and welding the lug to that but that's what you do if you are stuck in the desert.
I only use the trailer for odd trips to the tip or whatever so I want to keep it simple.
facade wrote: It has to be pull off clean all that gunge out and have a good look, look like bearings to me.
Yes I agree. The nut needed a 5/16" socket (not nylock - same size as the the wheel nut) and the washer was a a big penny washer job like you describe.
The four bolts holding the axle on were entertaining - to say the least.
- Dave cc
- Visitor
If bearing has spun on the stub axle due to faliure could be in a world of pain getting that off
Do I sense a hacksaw event then?? In truth I never use a hacksaw.............just a grinder.
- Dave cc
- Visitor
www.erde-trailers.com/hub102-erdeacute-1...b-assembly-530-p.asp
If your stub axle is 1" OD plain and the wheels are 4" PCD you can use the £17.99 one off eBay
You have to get the old one off to be sure.
