BigJimnyMeet 2024
× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Brake balance valve
24 Jul 2013 09:05 #78052 by helijohn
Brake balance valve was created by helijohn
After the fun and games I had at the MoT I am considering making this gizmo more purposeful. When one or two of us sat in the back the rear brakes got to be nicely efficient. The rear seats do weigh something, possibly as much as a child, so with them out the rear end is running lighter. Now I know we don't want the back brakes coming on hard and fast when the rear end is light but having seen the numbers on the dyno I would say at the moment it is like having no real rear brakes. Roughly the front brakes pulled about 220 on the indicator while the rear ones did about 60 but that went up dramatically with one or two persons in the back. As it seems that the rear brakes are really not man enough for anything other than the Noddy wheels I am wondering if a little alteration in the tension on the spring is called for. It won't need much.
Do it right - use Hammerite
When the blue light is flashing I am kidding.
24 Jul 2013 15:30 #78073 by supergaz
Replied by supergaz on topic Brake balance valve
Is your jimny lifted?
24 Jul 2013 16:18 #78076 by helijohn
Replied by helijohn on topic Brake balance valve
supergaz wrote: Is your jimny lifted?
Nope.
24 Jul 2013 18:42 #78091 by supergaz
Nope.
Thought id ask as this often is forgotten when lifts are done.
24 Jul 2013 18:48 #78092 by helijohn
supergaz wrote: Thought id ask as this often is forgotten when lifts are done.
I thought that might be it. I am trying to work out if the spring needs to be a mm longer or shorter. :unsure:
  • page
  • Visitor
  • Visitor
24 Jul 2013 19:34 #78098 by page
Replied by page on topic Brake balance valve
I am busy building a trayback and I was wondering if I could take this off. And would the brakes work and pass the mot
  • markyp2000
  • Visitor
  • Visitor
24 Jul 2013 19:45 #78102 by markyp2000
Replied by markyp2000 on topic Brake balance valve
The brakes would work but every time you brake the rear will lock up and may spin you out and it would be an mot fail if there was signs of it being fitted
24 Jul 2013 20:02 #78104 by helijohn
markyp2000 wrote: The brakes would work but every time you brake the rear will lock up and may spin you out
Can't speak for others but mine are not strong enough.
24 Jul 2013 20:39 #78112 by jimkyx
Replied by jimkyx on topic Brake balance valve
Hi Markyp2000
How did you stop the back end locking up after you fitted the rear disks?
  • markyp2000
  • Visitor
  • Visitor
24 Jul 2013 20:51 #78118 by markyp2000
It doesnt lock up at all where the brake flexi comes to the axle i just had a shorplt bit of pipe into a T piece and split it one to each side
  • Bits4Vits
  • Visitor
  • Visitor
24 Jul 2013 22:16 - 24 Jul 2013 22:19 #78125 by Bits4Vits
Replied by Bits4Vits on topic Brake balance valve
trailmaster's solution is to lift the mounting point of the brake bias mechanism's spring to suit the 2" lift -
Photo blatently nicked from JimnyBits' store :whistle:
www.bits4vits.co.uk/store/trailmaster/ji...racket/prod_915.html
Last edit: 24 Jul 2013 22:19 by Bits4Vits.
25 Jul 2013 11:00 #78139 by facade
Replied by facade on topic Brake balance valve
I wouldn't mess, just stick some weight in the back for the MOT, messing might make the backs lock up too easily in the wet.
In The Olden Days I had a Hilman Imp. When I took it for MOT at a place with one of those new fangled roller testers, instead of a tapley meter, the fronts just locked out at hardly anything and kicked it out of the tester (the engine was in the boot ;) ) It took me and a spare mechanic sitting in the front boot affair to get it to pass.
Time to create page: 0.173 seconds
Powered by Kunena Forum
