× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Removing rear seats
  • Teds Jimny
  • Visitor
  • Visitor
06 Mar 2013 18:34 #64757 by Teds Jimny
Removing rear seats was created by Teds Jimny
Does anyone know if you can remove the standard rear seats out of a 2001 jimny? They fold down etc but I want to make it into a flatbed at the back, I'm having trouble finding bolts to undo?
  • BigMat
  • Visitor
  • Visitor
06 Mar 2013 18:43 #64760 by BigMat
Replied by BigMat on topic Removing rear seats
Sure you can look under the front of the seats for the bolts. Then you can fit a piece of chequer plate in the back for a nice load area or wood if you want a cheaper option :)
  • markyp2000
  • Visitor
  • Visitor
06 Mar 2013 18:45 - 06 Mar 2013 18:47 #64762 by markyp2000
Replied by markyp2000 on topic Removing rear seats
Remove the trim inbetween the rear seats undo 4 bolts then in the lower left on the left seat peal back the material and undo he bolt same on the othe side that removes the back ane lift up the base and undo the 4 bolts holding them on
Last edit: 06 Mar 2013 18:47 by markyp2000.
  • rogerdadodger
  • Visitor
  • Visitor
06 Mar 2013 18:50 - 06 Mar 2013 18:52 #64765 by rogerdadodger
Replied by rogerdadodger on topic Removing rear seats
Under the cover that goes around the seatbelt catches there are two bolts that go down through the seat hinge into the floor on the seatbelt side of the chair . Then on the other there's a stud that sticks out from the wheel arch, if you pull the seat foam to one side there's a nut that needs undoing from the end of the stud. Then there are two bolts under each seat base & the carpet just pops on with poppers!
Good luck :)
Last edit: 06 Mar 2013 18:52 by rogerdadodger. Reason: Spelilng
  • Teds Jimny
  • Visitor
  • Visitor
06 Mar 2013 19:10 #64767 by Teds Jimny
Replied by Teds Jimny on topic Removing rear seats
Can you buy these chequer plates per cut to fit a jimny? Or do you have to cut it yourself?
  • supergaz
  • Visitor
  • Visitor
06 Mar 2013 19:22 #64773 by supergaz
Replied by supergaz on topic Removing rear seats
Teds Jimny wrote: Can you buy these chequer plates per cut to fit a jimny? Or do you have to cut it yourself?
Look on off road armourys website, they do a chequer plate load liner.
  • markyp2000
  • Visitor
  • Visitor
06 Mar 2013 19:24 - 06 Mar 2013 19:28 #64774 by markyp2000
rogerdadodger wrote: Under the cover that goes around the seatbelt catches there are two bolts that go down through the seat hinge into the floor on the seatbelt side of the chair . Then on the other there's a stud that sticks out from the wheel arch, if you pull the seat foam to one side there's a nut that needs undoing from the end of the stud. Then there are two bolts under each seat base & the carpet just pops on with poppers!
Good luck :)
There are 4 bolts under the cover 2 for each seat and there is no need to undo the nut on the stud just unvelcro the lower outer corner of the back and undo the 12/14mm bolt remove seat back then remove the nut on the bracket
Last edit: 06 Mar 2013 19:28 by markyp2000.
  • gus2000
  • Visitor
  • Visitor
06 Mar 2013 19:56 #64784 by gus2000
Replied by gus2000 on topic Removing rear seats
With a good carpet.
transport the dog
to load a lot of baggage
Gustavo
07 Mar 2013 04:59 - 07 Mar 2013 16:24 #64825 by Halford
Replied by Halford on topic Removing rear seats
click here for 2005+ rear seat removal ...... your's will be similar
click here for my rear load space project
Last edit: 07 Mar 2013 16:24 by Halford.
The following user(s) said Thank You: gus2000
  • Teds Jimny
  • Visitor
  • Visitor
07 Mar 2013 15:53 #64852 by Teds Jimny
That's a neat job there with the wood!
  • Teds Jimny
  • Visitor
  • Visitor
07 Mar 2013 15:55 #64853 by Teds Jimny
The plastic which fits over the seat belt anchor point is loose but I can't see a join in it to take the plastic off, or do I have to snap it off? :(
07 Mar 2013 16:28 - 07 Mar 2013 16:34 #64854 by Halford
:unsure: not sure which bit you mean, your's may be different to mine (2007)
but here's a pdf guide to remove the rear trim (which houses the rear belts)
liking Gustavo's dog ;)
Last edit: 07 Mar 2013 16:34 by Halford.
Time to create page: 0.116 seconds
Powered by Kunena Forum
