BigJimnyMeet 2024
fitting my lift kit (insert expletives)
- zaine
- Visitor
27 Jun 2012 12:15 #42980
by zaine
Replied by zaine on topic Re: fitting my lift kit (insert expletives)
does look a top job that
- nicho
- Visitor
27 Jun 2012 14:53 #42986
by nicho
Replied by nicho on topic Re: fitting my lift kit (insert expletives)
looks good tryed doing my fronts last night couldt undo the top nut it turns but so dose the bit underneath,any advice going to have another go soon.o and i dont have a grinder.thanks.
- nicho
- Visitor
27 Jun 2012 17:07 #42996
by nicho
think il be buying new nut and bolts off martin and a grinder.
- newbiepaul
- Visitor
28 Jun 2012 15:52 #43073
by newbiepaul
Replied by newbiepaul on topic Re: fitting my lift kit (insert expletives)
Hi nicho sorry for late reply i work shifts for my sins,easiest way i found was just to grind the top nut straight off the shock ,no messing about.where abouts are you in the country mate
- nicho
- Visitor
28 Jun 2012 16:38 #43078
by nicho
clitheroe lancs, thats what i was thinking i might have to do,i dont have front shocks yet i was going to get shock spacers but now thinking about getting sum shocks inseted and grinding them off.thought ther might be some were to put a spanner under the top shock bolt as well as the top.
- newbiepaul
- Visitor
28 Jun 2012 16:49 #43079
by newbiepaul
ahh a fair way from me was gonna say you could borrow me grinder lol,
ahh yeah you dont wanna be grinding them off if youve got no replacments,can you not get a pair of grips underneath the shock mount and stop the rod turning ?
- markyp2000
- Visitor
28 Jun 2012 16:52 #43080
by markyp2000
Replied by markyp2000 on topic Re: fitting my lift kit (insert expletives)
on top or the shock there shouls be a flat edge above the nut to get some mole grips on also aply some heat if you can or go to a plum center and get some pipe freeze that might do the trick
- Thank you received: 75
28 Jun 2012 17:59 #43083
by robs5230
standard jimny - for now
Replied by robs5230 on topic Re: fitting my lift kit (insert expletives)
what do the front springs look like ? is there much bow in the spring due to the axle tilting ? could you post a pic ? i'm looking at changing my suspension as its a bit tired and would just like to see how yours looks. cheers
- newbiepaul
- Visitor
28 Jun 2012 18:22 #43088
by newbiepaul
yeah rob no hassle il post it up tommorow if thats ok as im off to work shortly
28 Jun 2012 19:22 #43093
by robs5230
nice one
- nicho
- Visitor
03 Jul 2012 19:29 #43471
by nicho
one front lower shock bolt undone heat undo abit heat undo abit defo need new new nuts n bolts.
Time to create page: 0.134 seconds
