Turbo M16A Jimny
12 Feb 2022 19:20 - 12 Feb 2022 20:52 #241826 by Motleycrew
Replied by Motleycrew on topic Turbo M16A Jimny
It does look like a turbo should be in there, hopefully this small fast spooling turbo will liven up it up. Definitely not the most sensible idea I have had!
Last edit: 12 Feb 2022 20:52 by Motleycrew.
12 Feb 2022 21:23 #241828 by Martin416
Replied by Martin416 on topic Turbo M16A Jimny
Wheres the fun in being sensible!
SJ416 spi, 33s, Cage, Rocklobster
The following user(s) said Thank You: Motleycrew
13 Feb 2022 12:12 #241838 by Motleycrew
can anyone help me out? trying to establish what type of idle control valve the Jimny uses. is it a stepper motor inside?
cheers
13 Feb 2022 16:50 #241840 by Motleycrew
So I believe the idle control valve is a stepper motor which means I will have to upgrade to the next model in the Links ECU line up called “storm” I bought the the ECU in September but luckily the company I bought it from (Brands hatch performance) does a exchange plus 15% within 6 months but may get it cheaper as it’s unused. Absolute fail
13 Feb 2022 17:01 #241841 by Motleycrew
This was the auxillary output page where I realised my mistake. The next ECU has that capability
14 Feb 2022 14:30 #241847 by Motleycrew
Contacted Brands hatch performance and they are happy to upgrade the ECU but said they wouldn’t bother as the current ECU can manage the idle via some trickery. My job is to either step back the stepper motor or blank it off completely. There is a screw that can adjust the opening on the throttle plate but I will get the mappers to sort that out for me. Crisis avoided! £450 saved…
