Giving the Jimny a birthday
10 Mar 2021 17:52 #233622
Replied by Riccy on topic Giving the Jimny a birthday
More great progress my friend!
Seeing this makes me wish I had taken the body right off like you have, but I dont have the luxury of the lift. Looks so much easier to get at the nasty tinworm how you are doing it. No doubt much more effective too. You should have an ever lasting jimny after all this :laugh:
p.s. Glad to hear that gearbox is still doing well. It cost a fortune to have it out and rebuilt when I had it, so it should be reliable now. Worth giving the intermediate prop the once over at the gearbox end while its easy to get at. The cap is known to leak the oil out, causing problems inevitably. Can be cleaned up as sealed again with resin glue I believe
10 Mar 2021 21:35 #233632
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Replied by Mike G on topic Giving the Jimny a birthday
Thanks Riccy,
Before the garage and lift became available, I was even considering building some weird wooden lift to get the body off in my drive
. Not only would the neighbours hate me for having bits of broken car on my driveway, they'd have been wondering why I was building a gallows. The lift has been a life saver, wouldn't have been able to do any of this without it.
I'll have a look at the intermediate prop. I've not done anything with that so far. I'll be cracking on with as much welding as I can as I've only got a week left in the garage, so I'll have to have it back in one piece (at least rolling) before next Wednesday. A few late nights ahead for me I think.
10 Mar 2021 22:01 - 10 Mar 2021 22:03 #233633
by Mike G
Wednesday 10th March,
Jobs done:
Today was the day I've not been looking forwards to. Before I split the jimny, I'd hired someone to do the welding, but he let me down and only turned up twice in over two months, doing what I'd equate to two days work. This meant that if anyone was going to do it, it would have to be me. However, this has more plusses than minuses as I'm now able to weld, at least for my own work (I certainly couldn't charge anyone) and I'm now quite happy cutting out and bending panels to fit spaces.
As you can see in the pictures, there's so much orange dust in there, you'd think these were snaps taken by the Mars rover. So much rust in so many places. Think I have my work cut out for me.
Jobs for tomorrow:
Think once I get the rear arch area done, I'll have a good base for putting in the boot floor panel. Although, I don't think I'll get all of that completed in one day.
I'll have to relocate the lifting pads for the car lift so that I can get to the last bolts for the front panels. That way, I can get a look at how I can approach the slam panel and also decide how I'm going to brace it.
Jobs done:
- hammered round all the hotspots on the body to see where all the patching need to be done
- wire wheeled a few areas to see how far back the wafer thin metal went until MOT strength steel appeared. At least the remaining body mounts are good and solid. (front two behind the slam panel were repaired for me already)
- Welded the remaining 3/4 of the port sil till I hit the rear arch area
- removed most of the bolts for the front two wing panels (couldn't remove them as access to the bottom bolts were obscured by the car lift rubber lifting points
- Cut out a chunk of sil just before the rear arch
- cut and fitted a piece to fill the hole. Decided to weld this tomorrow as it was getting late and I have a lot to do in the port rear arch
Jobs for tomorrow:
Last edit: 10 Mar 2021 22:03 by Mike G.
- Thank you received: 1855
11 Mar 2021 04:25 #233636
Replied by Lambert on topic Giving the Jimny a birthday
That's going to keep you busy. Just think about the end result, it'll be over quicker that way.
11 Mar 2021 21:27 #233665
by Mike G
Definitely Lambert. I'm throwing as much time at it as possible. At least I'm not discovering more work now, I'm on the home straight.
11 Mar 2021 21:45 #233666
by Mike G
Thursday 11th March,
Work done today:
My por15 paint arrived today along with my brake caliper paint., but I don't have enough time in the shed to do that stuff right now. There will be a lot of little jobs that I can get on with when the car is back on my driveway.
Tomorrows jobs:
hopefully will get the back end welding all done. If so, I'll clean up all the welds and buff off the old underseal so that when it comes to coating, it will get a decent hold. I have some QD primer, so will give it all a coat (after seam sealing the welds) as soon as possible so that the rust doesn't get a chance to set in. Bit optimistic, as I'll probably still be messing about welding by the end of play tomorrow.
Work done today:
- finished port sil welding
- finished port wheel arch welding beside sil
- cut out boot floor
- marked out areas to cut out on wheel arches
- cut out stencils for both wheel arches
- cut out metal from stencils for wheel arches
- looked out some metal to brace the front of the vehicle to keep it square when doing the slam panel
Tomorrows jobs:
Time to create page: 0.189 seconds
