restoration after 10 years in the driveway
- Thank you received: 6
17 Jun 2021 23:43 - 18 Jun 2021 00:34 #235886
by Mr CC
Replied by Mr CC on topic restoration after 10 years in the driveway
kingpin bearings renewed and all new bolts, completely stripped down the front calipers and renewed sliders, rubbers, seals and bleed nipples, New discs as well. The yellow sleeving is just for show and easier to clean, renewed the pressure pipes back to the flexi hoses which drop down to the control arm, renewed all flexi hoses as well, with new spring clips. used kunifer and 6mm brass tees. made new brackets with galvanised sheet steel. putting a bit of silver hammerite on exposed edges. seems to be a lot slicker engaging 4WD. brakes are now instant, renewed the brake pipes all over, only thing I left was the rear cylinders which I renewed before taking off the road.
Also
new stabilising link bars.
new track rod ends
Also
new track rod ends
Last edit: 18 Jun 2021 00:34 by Mr CC.
17 Jun 2021 23:45 #235887
by Mr CC
made a new bracket for the towbar socket from 3mm steel and welded it on to the towbar
17 Jun 2021 23:47 #235888
by Mr CC
looking very clean underneath, a bit of touching up, its been almost a year since some of it was painted (hammerite of course)
17 Jun 2021 23:49 - 18 Jun 2021 00:04 #235889
by Mr CC
painting all the bumpers with 3 layers of black stonechip then 3 layers of laquer. all new clips, screws and bolts going on as they are shiny and cheap and will last,
Last edit: 18 Jun 2021 00:04 by Mr CC.
17 Jun 2021 23:54 - 18 Jun 2021 00:17 #235890
by Mr CC
spaghetti time with the wiring, Im studying sound engineering and just passed HND. so need a good system, installing a 10 speaker system, also rewired the connections to the rear lighting and towbar. fitting a 2 din android head unit. not the most expensive at the moment, but will get it all working.
Last edit: 18 Jun 2021 00:17 by Mr CC.
17 Jun 2021 23:57 - 18 Jun 2021 00:37 #235891
by Mr CC
new timing belt fitted, as the manual says 80,000 miles, and the jimny has done 82,000. Never fitted one before so very nerving. watched videos over and over, marked and checked over and over, had multiple cigarettes and coffees before doin the 15 minute swap
cleaned and painted the pulleys when they were off.
expressions of joy as the jim started first time after the timing belt.
and also the engine sounded better at higher revs as well.
Last edit: 18 Jun 2021 00:37 by Mr CC.
18 Jun 2021 00:07 - 18 Jun 2021 00:39 #235892
by Mr CC
Last edit: 18 Jun 2021 00:39 by Mr CC. Reason: extra content
18 Jun 2021 00:10 #235893
by Mr CC
still more happening at the moment and the jim is almost ready, doing some snagging and fitted new brackets on the habdbrake cables. just some paint touch up and one weld bead on the sill about 2 inch where I ran out of wire.
then its time for the interior,
- Thank you received: 1628
18 Jun 2021 05:58 #235897
Replied by Lambert on topic restoration after 10 years in the driveway
Good work, another saved from the crusher!
18 Jun 2021 10:34 #235909
by gv42
Replied by gv42 on topic restoration after 10 years in the driveway
Very good work on the JIMNY
18 Jun 2021 14:05 #235912
by Mr CC
Thanks, theres been opportunities to do things that would just be an MOT pass, but I thought I wanted to do a thorough job, so it takes longer and more expense, but will be worth it in longevity.
18 Jun 2021 14:12 #235914
by Mr CC
Thanks, there was no way it was getting destroyed, jimny's are built on a solid foundation with the ladder chassis thats very well designed. I'm old school with cars, the less fancy things on it, the less can go wrong. I got waxoyl, but decided not to use it, maybe too much surface rust inside the box section at this time. I decided to use a cheap supermarket maintenance oil, which I will spray inside twice a month. maybe waxoyl or dinitrol next year.
Time to create page: 0.254 seconds
