restoration after 10 years in the driveway
  • Mr CC
08 Aug 2020 12:25 - 08 Aug 2020 12:28 #226346 by Mr CC
Replied by Mr CC on topic restoration after 10 years in the driveway
Lambert. I'm about 5 miles outside Edinburgh
thanks for the encouragement. any advice is always welcome.
Last edit: 08 Aug 2020 12:28 by Mr CC.
  • Mr CC
09 Aug 2020 22:05 #226432 by Mr CC
painted the tank after taking it out
  • Mr CC
09 Aug 2020 22:09 #226433 by Mr CC
had to renew the filter,
snapped the connector pipe when taking it out
(more on tank removal thread)
car is at 81,000 miles so needed done anyway
cleaned up the collar for painting with hammerite
put it all together for re-fitting
  • Mr CC
09 Aug 2020 22:18 - 09 Aug 2020 22:22 #226434 by Mr CC
prepared top of the tank by thinning hammerite with wd40 and painting the top flange. very thin coat (will not seize bolts)using an M6 tap to clean the threads, then cutting the bolts to size (around 10mm long)you only get about 5 threads past the bottom flange without touching the tank topalso painted the tank protectoryellow is definitely the right colour, will stick on a rubber trim when I get the chance
Last edit: 09 Aug 2020 22:22 by Mr CC.
  • Reason2doubt
11 Aug 2020 08:32 #226502 by Reason2doubt
Replied by Reason2doubt on topic restoration after 10 years in the driveway
Nice little updates on your progress. Keep it up! Looking good.
  • Mr CC
11 Aug 2020 22:43 #226539 by Mr CC
Thanks Reason2Doubt, nice to find folks who understand restorations, getting a blow torch for the gas canister tomorrow, have to work on all those seized bolts with heat while the tank is out.
Waiting for the garage to get in touch so they can approve the rebuild of the lower tailgate.
Time to create page: 0.182 seconds
