restoration after 10 years in the driveway
  • Mr CC
18 Jun 2021 00:07 - 18 Jun 2021 00:39 #235892 by Mr CC
Replied by Mr CC on topic restoration after 10 years in the driveway
putting rubber flooring in the back up to the shelf before the footwell, jammed some props in to help it stick to the adhesive overnight. 3mm rubber so a cheap heat gun from argos was essential.
made an upstand at the very rear of the car so it doesnt have an ATSOD trap (all the ..............Day )
Last edit: 18 Jun 2021 00:39 by Mr CC. Reason: extra content
  • Mr CC
18 Jun 2021 00:10 #235893 by Mr CC
still more happening at the moment and the jim is almost ready, doing some snagging and fitted new brackets on the habdbrake cables. just some paint touch up and one weld bead on the sill about 2 inch where I ran out of wire.
then its time for the interior,
18 Jun 2021 05:58 #235897 by Lambert
Good work, another saved from the crusher!
18 Jun 2021 10:34 #235909 by gv42
Very good work on the JIMNY
  • Mr CC
18 Jun 2021 14:05 #235912 by Mr CC
Thanks, theres been opportunities to do things that would just be an MOT pass, but I thought I wanted to do a thorough job, so it takes longer and more expense, but will be worth it in longevity.
  • Mr CC
18 Jun 2021 14:12 #235914 by Mr CC
Thanks, there was no way it was getting destroyed, jimny's are built on a solid foundation with the ladder chassis thats very well designed. I'm old school with cars, the less fancy things on it, the less can go wrong. I got waxoyl, but decided not to use it, maybe too much surface rust inside the box section at this time. I decided to use a cheap supermarket maintenance oil, which I will spray inside twice a month. maybe waxoyl or dinitrol next year.
Time to create page: 0.306 seconds
