26 Jan 2020 23:15 #217721 by gv42
Replied by gv42 on topic Dave's la(te)st buggy build...
looking good dave keep up all the good work and all the best too
  • X8GGY
  • Platinum Member
  • Platinum Member
  • but currently AWOL
29 Jan 2020 16:42 #217811 by X8GGY
Bit more today...
I wanted to get the seats out before they got burnt with welding and grinding...
A little bit of work on them first, as where the original seat belt anchroages were on the subframes were in the way of the seats fitting properly... so I cut the mounts ff flush with the rails, and then drilled a new hole lower down on the rail and used some seamless tube as a spacer to get the seatbelt clips further out, and bolted them on with 12mm bolts washers and nylocs.. and then painted them...
And then bolted the seats back on firmly, and finally...
Popped them in one of our delivery cages to store behind the shop out of the way for now ;)
I then turned my attention back to the already-cut bonnet edge, and experimented with some oval tube I had ordered and stored in the garage,,,
I cut slits in the back of it and manipulated it until it sat right...
And then..
Welded it in place and ground and sanded it back... there's a few welding distortions in the bonnet skin :( But it'll do! It's only an offroad buggy for some summer fun! And it will eventually be brush painted as it will only get scratched anyways! ;)
Not too bad... some thick yellow JCB paint is standing by for the final finish! :lol:
29 Jan 2020 18:17 #217818 by Riccy
Good progress mate ;-)
30 Jan 2020 23:34 #217875 by kirkynut
I've just re-read this from start to finish and realised I'd missed a few bits. You've really achieved quite a bit on this Dave.
I'm loving the sides where you've filled in the cut down doors and the Vector winch set up is coming along nicely.
  • X8GGY
  • Platinum Member
  • Platinum Member
31 Jan 2020 11:38 #217893 by X8GGY
Thanks a Guys... it’s getting there slowly... ;)
  • X8GGY
  • Platinum Member
  • Platinum Member
02 Feb 2020 17:54 - 02 Feb 2020 17:56 #217994 by X8GGY
NOTHING today! :(
I was out Friday night to one of the wife's friends, and the husband had a full bar/pub in the back garden?! So we rolled home at 2am, and I then got up at 5:30am to do the papers, and worked until 8pm... Both of our daughters were home for the weekend before leaving together this afternoon for a few days in Barcelona, so I couldn't really abandon them and retreat to the garage...
So, a nice lie-in, family cooked breakfast, wave them off just after noon, so spent a couple of hours updating eBay listings, a nap for a bit, an hour in the hot tub, and about to have chicken dinner with the missus, now we're "home alone"!
A bit more relaxed about stuff at the moment :blink:
Dave ;)
Last edit: 02 Feb 2020 17:56 by X8GGY.
  • X8GGY
  • Platinum Member
  • Platinum Member
09 Feb 2020 18:27 - 09 Feb 2020 18:30 #218231 by X8GGY
Back to it today, determined to get it finished...
So today I welded up the driver's half-door, the new top to join the inner and outer skins, filled all the holes in the door, and some tube in the old window channel passed the mirror mount...
Attached to the inner skin too, they'll eventually be an aluminium chequer plate 'step' on the lower half of the door, and it'll fold into the inside to make a door panel too...
Hoping to get out in the garage again on Wednesday and enclose the rear of the cab cutoff...
Last edit: 09 Feb 2020 18:30 by X8GGY.
09 Feb 2020 19:19 #218242 by Lambert
Very nice. You should be proud of yourself.
  • X8GGY
  • Platinum Member
  • Platinum Member
09 Feb 2020 21:11 #218248 by X8GGY
Thanks! Should look better with some (yella) paint...?
10 Feb 2020 05:31 #218254 by Lambert
Everything should be yellow, by far the best colour!
  • X8GGY
  • Platinum Member
  • Platinum Member
10 Feb 2020 16:57 #218266 by X8GGY
My inspiration is very yellow...
10 Feb 2020 17:58 #218270 by Riccy
Loving the chopped down doors B)
How will you open the door? small handle inside. Might I suggest the lever that used to open the fuel filler flap could be useful to you here? ;-)
Time to create page: 0.495 seconds
