- Thank you received: 1978
05 Jan 2021 05:50 #231504
That looks comfortable. Real leather or vinyl?
05 Jan 2021 08:26 #231511
by RainerK
Replied by RainerK on topic Dave's la(te)st buggy build...
With this type of junction boxes and junctions I had troubles in the past, especially when they get wet and corroded, i.e. like trailer connections.
If you want to use this type you could crimp the ends of the wires (this already helps a lot) and use some fatty corrosion protection inside the box (I would use FluidFilm Max spray) or go for a crimped spade type junction box.
Out of whatever reason my junction boxes tend to be a little moist inside all the time and then there is corrosion with faulty contacts.
- Thank you received: 923
05 Jan 2021 11:56 - 05 Jan 2021 13:59 #231520
Lambert - "Faux Leather" :lol: - black vinyl to you and I... they are Bad Boy Classics BB6 Bucket Seats, bought a couple of years ago...
Bad Boy Classics
Comfortable, supportive and "waterproof"...
RainerK - Thanks for that, I'll keep an eye on it, but it is a fully sealed box, and mounted "internally" - not that there's (full) doors or a back to the body tub! :lol:
Bad Boy Classics
Last edit: 05 Jan 2021 13:59 by X8GGY.
06 Jan 2021 15:17 - 06 Jan 2021 15:24 #231566
More on therear lights wiring today...
I wrapped the unwanted offside rear wiring loom in black pallet wrap and insulating tape, finished with ty-wraps and then stuck in down the inside of the soft-top pillae out of the way, and then bolted my seat back in
And then prepped all the rear lights, i.e. they are mounted but not wired yet...
Offside rear light - they are Suzuki SJ lights sourced from JimnyBits, with light-guards off a fella on eBay... the fog-light is now fitted below, on the back of the waffle board mounts...
LED number plates fitted spot-on to the perforated sheet... the mounting holes lined up perfectly?! :woohoo: (The number plate is loose that's why it's on a slope... the wiring for the number plate lights need to be hidden behind the 'plate... with ty-wraps through the perforated sheet
And the hi-level brakelight on the back of the 'halo hoop' that surrounds the roofline to protect the cab and the soft-top... it's the same as the foglight, so nice and bright multi-LEDs
Yes, it's slightly wonky
But the holes are drilled now! :lol:
Wiring on Sunday then!
Last edit: 06 Jan 2021 15:24 by X8GGY.
06 Jan 2021 15:30 #231567
I decided to knock off at three and give the dogs another good walk (they had a little one this morning)... and when I ventured out of the garage I was surprised how good the weather was... Hmmm, yes, I think I will...
(still listing to the left, I'll have to take the 15mm spring spacer off the offside spring! D'Oh!)
I think I'm happy with it... it's the first time in a while it's been out of the garage... :ohmy:
- Roger Fairclough
- Thank you received: 224
06 Jan 2021 15:54 #231570
by Roger Fairclough
Replied by Roger Fairclough on topic Dave's la(te)st buggy build...
Fabulous build Dave but be aware that you will be plagued by:-
1) The Plod, "Is this your car sir etc etc etc".
2) Small boys, "cor give us a ride mister".
3) Old ladies shaking their brollies "menace on the roads, shouldn't be allowed"
4) Nuns, repeatably crossing themselves.
Oh, by the way, are the seats comfortable? The standard Gen.4 seats are pretty hopeless at comfort or body control.
Roger
Roger
Time to create page: 0.331 seconds
