- Visitor
14 Oct 2018 21:00 #196771
I wouldn't have thought the MoT man would be looking for that, cracked plates or such yes.
My 26 year old 2.5TD just passed on Thursday. Admittedly I greased all the grease points (yes it has them - loads of them) which helps and I took it on a run with a diesel additive to help emission, gave it a vacuuming to keep up appearances but otherwise did nowt and I was a nervous wreck; worse than a dentist appointment jitters so I wish you all the best for yours.
Replied by helijohn on topic Dave's "S200KYS" Jimny 'laner Build...
S200KYS wrote: 2. Mis-spaced number plates - My Jimny's registration should be displayed as "S200 KYS" by I had the normal plates made as "S200KYS" so it reads (hopefully!) as 'SUZUKIS" (well, that's the idea anyway!) So I have a pair of perfectly spaced plates in the garage to swap on for the MOT test...
The topic has been locked.
- Thank you received: 923
15 Oct 2018 06:00 #196781
Replied by X8GGY on topic Dave's "S200KYS" Jimny 'laner Build...
Yup, two failure points last year on (very slightly) mis-spaced number plates... I mentioned Dave was firm but fair
- Visitor
15 Oct 2018 07:37 #196788
Once they get a fixation that's it. Some get reps like wanting to fail brake pipes - had one who checked the petrol filler cap with a vengeance. It's pathetic really.
S200KYS wrote: Yup, two failure points last year on (very slightly) mis-spaced number plates... I mentioned Dave was firm but fair
17 Oct 2018 11:37 - 17 Oct 2018 12:00 #196837
Ah... epic fail
Three of the eleven faults are because the anti rollbar disconnect was not bolted up...
Zanfi panhard bracket has a crack / fracture in it
Adjustable front panhard rod nut is loose
Front shocks are AVOs... hope the bushes can be changed?
[strike]Track rod end loose? Haven’t spotted that one yet, in Post Office today but S200KYS is parked outside[/strike]...
Edit: just the lock nut is loose...
ARBs droplinks feel loose as it’s disconnected
Rear shocks loose? Repositioner brackets?
Oil leak from axle over brake disc hopefully just an oil seal?
Off Friday this week, so have a work list
Ah... epic fail
Last edit: 17 Oct 2018 12:00 by X8GGY.
- Thank you received: 1811
17 Oct 2018 12:42 #196838
Wow. At least they are fairly simple fixes.
- Thank you received: 115
17 Oct 2018 12:47 #196839
by maverick
Jalapeño, IISY?
Replied by maverick on topic Re:Dave's "S200KYS" Jimny 'laner Build...
Simple fixes for a man of Dave’s ability
Jalapeño, IISY?
17 Oct 2018 16:41 #196840
Replied by X8GGY on topic Re:Dave's "S200KYS" Jimny 'laner Build...
Simple fixes, yes, but that's what makes it more embarrassing missing them in the first place!
Mostly loose nuts...
Busy Sunday concentrating on the big issues and missed the little bits... and forgot to fasten the ARB disconnect back up?! Must have driven back from the Lakes with it still off?...
- MadsV
- Visitor
17 Oct 2018 18:56 #196842
by MadsV
Replied by MadsV on topic Dave's "S200KYS" Jimny 'laner Build...
I wouldnt say that a mechanic checking the filler cap is pathetic, its a list that have to be checked. A filler cap has to be closed/sealed because of fire hazard, spills etc. Its not the shops that make the rules. If they dont check that your brake pipes are good, and they fail after 100miles and you crash, whos fault is it then?
I dont want to be ”that annoying guy” but after working along side by people doing MOT’s daily and knowing the rules for faults i cant just say nothing. Here in norway there are new rules all the time, making it more difficult everytime to do a bad job. Everything is online and the department can pop by anytime and want to do a recheck just to see if its right. From 2019 we cant even do our own cars on the house, no close relatives, we have to go somewhere else.
Difficult yes, but you dont want to meet the car with shit tires and no brakes on the road
18 Oct 2018 05:40 #196848
Agreed, they work to a list of things to check, and as I said earlier Dave is always firm but fair, and has spotted things I have missed...
The following user(s) said Thank You: MadsV
19 Oct 2018 15:36 - 19 Oct 2018 15:53 #196872
I wrote a big long post with lots of photos about fixing all the MOT failure items, but security blocked everything, and I'm not writing it all again...
Suffice to say all the points have been attended to...
Last edit: 19 Oct 2018 15:53 by X8GGY.
19 Oct 2018 17:05 #196875
Replied by Riccy on topic Dave's "S200KYS" Jimny 'laner Build...
Nooo! thats happened to me before and ironically on this very post its just happened again...
If it does it to you again, try selecting the reply option from the bottom 'action' button on a post, magically everything re-appears
So is S200KYS re-tested and ready to rock, or yet to go back?
20 Oct 2018 05:48 #196888
Re-test around eleven this morning... they said they'd squeeze it in for me
Time to create page: 0.231 seconds
