Re:Transfer case rebuild
3 years 7 months ago #248595 by lesgrandepotato
Set into the Tcase today. Planning to fit a set of 4.16:1 Sumo gears. I’ve got it mostly torn down. But I’ve not managed to pull the sleeve for the speedo drive.
Will that stop me pulling the main shaft out? It doesn’t feel like it’s keen to be shifting anytime soon… I guess it’s just pressed in there?
3 years 7 months ago #248598 by lesgrandepotato
Ok. Disappointingly it seems not. What’s the trick to getting the speedo sleeve out then? Bearing extractor hasn’t touched it…
3 years 7 months ago #248601 by mlines
Replied by mlines on topic Re:Transfer case rebuild
I assume you have removed the retaining bolt? If so it's lots of lubricant and careful heating
Sent from my moto g42 using Tapatalk
3 years 6 months ago #248711 by lesgrandepotato
Keeping the thread alive… in case others try this at home. Looks like the speedo drive can stay in for a 4.16:1 reduction.
I’ve got most of it torn down. The bearings are FT on the shafts tho! Just bought some new bearing pullers. They haven’t made a dent on them with 5 ton of pressure…
3 years 6 months ago #248714 by lesgrandepotato
Hmm. Ok mostly remantled. What sort of witchcraft is needed to get the detent balls back in?
3 years 6 months ago #248716 by lesgrandepotato
Hah! A deft push with a screw driver at a critical moment slips the lower detent back in.
Time to create page: 0.086 seconds
