My Jimny flat deck build - South Africa overlanding idea
- lookonimages
- Thank you received: 72
21 Nov 2025 09:56 #262868
by lookonimages
Replied by lookonimages on topic My Jimny flat deck build - South Africa overlanding idea
And note there will be 2 small doors in the middle and the door at back is quick release..
- lookonimages
21 Nov 2025 10:00 - 21 Nov 2025 11:35 #262869
by lookonimages
In the front behind the seats it look like this and will have 2 doors. .
Last edit: 21 Nov 2025 11:35 by lookonimages.
- Thank you received: 1995
21 Nov 2025 10:14 #262870
Replied by Lambert on topic My Jimny flat deck build - South Africa overlanding idea
This is giving me ideas for something in behind the back seats in temeraire but an audio enclosure instead of storage but still to give a mostly flat boot area. Keep up the good work!
The following user(s) said Thank You: lookonimages, Tallboy
29 Apr 2026 07:51 #264314
by Tallboy
Replied by Tallboy on topic My Jimny flat deck build - South Africa overlanding idea
Hi Lambert. Great design - I am going to steal it with pride!
Any chance of you sharing your cad files? Sketchup .skp would be best, but whatever you can would be a good start
29 Apr 2026 08:04 #264315
I'd love to but it hasn't materialised, to level off the back of the seats I'm now using a block of blue high density closed cell upholstery foam 12x5x36 inches as it's a lot lighter than an enclosure, I'm just waiting on the sewing department to make a cover to protect the foam. As for audio I'm still weighing up my options but it's currently looking like a high quality pair in the factory B pillar positions, but I am also wanting to save weight now more than anything while maintaining the 4 seat configuration so the whole audio system is under review.
07 May 2026 10:41 #264383
by Tallboy
looking at the pictures of the frame it looks like the early version had a simple flat iron bar acrosst he top. the later images seems to show a more robust welded square tube arrangement. Am i seeing this correctly, and if so, what wsa the reason for the change in design?
Time to create page: 0.189 seconds
