My Jimny flat deck build - South Africa overlanding idea
- lookonimages
- Thank you received: 72
29 Mar 2023 17:03 - 29 Mar 2023 17:17 #248303
by lookonimages
Replied by lookonimages on topic Re:My Jimny flat deck build - South Africa overlanding idea
Finally finished the passenger side deck that go over the passenger seat. This also can be used with seat completely removed. The deck is exactly the same hight as back deck.
It is fastened to front seat bolts
The back is fastened to to back deck part.
All points can be fastened / loosened by hand. No bolts nuts that require spanners.
By removing the seat completely you suddenly add a lot of space for overlanding.
Yes I am lone traveler.
(Yes the door side post still need to be powder coated..)
Last edit: 29 Mar 2023 17:17 by lookonimages.
- lookonimages
29 Mar 2023 17:13 - 29 Mar 2023 17:18 #248304
by lookonimages
Last edit: 29 Mar 2023 17:18 by lookonimages.
- lookonimages
29 Mar 2023 17:22 - 29 Mar 2023 17:22 #248305
by lookonimages
Best of all is you can have a proper sleep inside if you have to. Nice and flat. Tested and is comfortable for my length. Sure will be a tight fit for the bigger South Africans.
Last edit: 29 Mar 2023 17:22 by lookonimages.
29 Mar 2023 18:02 #248310
Replied by jackonlyjack on topic Re:My Jimny flat deck build - South Africa overlanding idea
The following user(s) said Thank You: lookonimages
29 Mar 2023 18:33 #248312
Replied by Soeley on topic My Jimny flat deck build - South Africa overlanding idea
Very nicely done!
- lookonimages
21 Nov 2025 09:17 - 21 Nov 2025 09:46 #262866
by lookonimages
Replied by lookonimages on topic My Jimny flat deck build - South Africa overlanding idea
Forward like quick few years. I am busy redoing the deck in stainless steel now that i learned some CAD.
Same prInciple.
-Use only jimny standard bolt on points.
-Ease of assembly. No drilling... just bolts and nuts.
-Use full area under deck including jack area.
-Ease of access from both back, top back as well as from behind front chairs.
Assemble, put in jimny. Bolt fasten. Add top deck with Pull down toggle latches. 2 top sections to enhance assesability. See photos.
Deck is about 10cm above back door bottom lip but in deep section about 19cm. Front behind seats 16cm.
A lot of space to keep tools recovery gear and a lot more safe and away from prying eyes especially in our lovely country.
Still in the metal. Powder coating happen next week.
Same prInciple.
Last edit: 21 Nov 2025 09:46 by lookonimages.
Time to create page: 0.304 seconds
