Re:My 01 Jimny, another Norwegian
  • MadsV
16 May 2018 22:16 #192761 by MadsV
Replied by MadsV on topic My 01 Jimny, another Norwegian
No I just cut it slightly over the narrow part, the dimension on the pick up tubes were the same.
Anyways the engine runs great, no problem with ignition after the cam ring swap. Its easier to hold higher speed, and it has greater torque.
It makes a different noise when i crank the engine, but starts just fine so. Also i forgot to tighten the oil filter, so I filled my driveway at home with some litres oil :lol:
It has a small exhaust leak somewhere, have to adjust the exhaust after making the bump in the downpipe.
  • MadsV
27 May 2018 16:01 #192980 by MadsV
Replied by MadsV on topic Re:My 01 Jimny, another Norwegian
Been driving for two weeks now, everything is still ok. Think the gas/mileage is down a bit also!
A friend of mine built me this small box
A nice little compartment
Going to fit a fire extinguisher some place also
27 May 2018 16:33 #192982 by Riccy
Very tidy addition :-)
29 May 2018 06:05 - 29 May 2018 06:06 #193014 by yakuza
That compartment is a great mod! I am definitely doing that to mine as well.
The dogs will love to have a larger flat space back there too. Now the larger one sits on the first floor while the smaller one lays in the basement. They are 44 and 60 kg so they really need the extra comfort.
Built from wood?
I placed my fire extinguisher in the pocket in the rear side panel.
Clas Ohlson (Norway) has one with a strap and a bracket that fits nicely.
edit: www.clasohlson.com/no/Housegard-brannslukker-2-kg-/34-155-2 '
Last edit: 29 May 2018 06:06 by yakuza.
  • MadsV
29 May 2018 06:13 #193016 by MadsV
Yes from wood, just a frame in the bottom and a lid :) I’ll check that fire instinguisher out, was looking a one 1kg at Jula, maybe thats small
29 May 2018 10:31 #193025 by yakuza
I think you will need two kg's to pass technical checks at most offroad events. (In Norway)
the clas ohlson is not the cheapest one, but i like the strap and it lookes tidy mounted in the pocket.
I do not want it to fly around inside the car if i get into a crash.
I have put out a fire in a car once with a two kg extinguisher. Considering the age of the car it was maybe a stupid thing to do, we probably should have let it burn even though it was a Ford Granada (jada, ekje noke Lada).
But I needed the two kg's as the fire started up again a couple of times until we got the battery unhooked.
And if your fire is inside the car you should empty as much powder inside the dash as possible to be sure your insurance company will wreck the car instead of fixing it. Make sure your insurance have fire coverage of course.
Time to create page: 0.199 seconds
