Re:My 01 Jimny, another Norwegian
- MadsV
12 May 2018 17:43 #192630
by MadsV
Cam ring on the 1.6 cam, fingers crosses that its acurate.
Plugged up with sealant
Sensor cap on and sealed
Water pipe with the bracket from Zukparts kit.
Engine mount on and radiator hose
Tomorrows issue, chopping off the top of the power steering tensioner bracket. I will try to maybe weld it on lower so I can use the hole to fit one bolt.
Power steering pump bolted on, these spacers were actually meant for the left engine mount. But mine bolted right on, and the power steering pump did not so I used them there instead.
Coil packs on, all from the G13BB.
G13BB dip stick
Alternator on, all brackets from G13BB.
Zukparts kit includes a fitting instruction also. Its not always correct, depends on the donor engine, but a good guide to have and a nice check list.
Tomorrow I have to get it in so I can get to work on monday :lol:
Replied by MadsV on topic Re:My 01 Jimny, another Norwegian
G13BB dip stick
- muto
12 May 2018 20:36 #192635
by muto
Replied by muto on topic Re:My 01 Jimny, another Norwegian
that is crazy... amazing work and greetings from finland!
- MadsV
13 May 2018 12:21 #192647
by MadsV
- MadsV
13 May 2018 18:28 #192660
by MadsV
14 May 2018 08:41 #192675
Replied by Daniel30 on topic Re:My 01 Jimny, another Norwegian
great work..... you don't hang about
16 May 2018 05:48 #192739
With half the diameter the area is allmost three times as big and trying to pull oil thru there means the oil must go at three times the speed in the narrow suction pipe. And that cannot be smart in my opinion. There will be a very high risk of getting foam in the oil or pressure drop.
However many have done so and that seems to work fine but i think it looks like crap
Must be a lot better to have the wider suction pipe like you do, and just like the original 1.6
Replied by yakuza on topic Re:My 01 Jimny, another Norwegian
I think you chose well to not follow the instructions and weld the narrow 1.3 oil pick up tube to the wider 1.6 suction tube.MadsV wrote: Here are the two sumps, you can see that the small baleno one is wider than the jimny one. Cutting and welding them tomorrow! Hoping to maybe get it in the engine bay when saturday is over
Time to create page: 1.035 seconds
