Re:My 01 Jimny, another Norwegian
- Thank you received: 2001
12 May 2018 04:43 #192612
Replied by Lambert on topic Re:My 01 Jimny, another Norwegian
Cool.
- MadsV
12 May 2018 11:02 #192616
by MadsV
Replied by MadsV on topic Re:My 01 Jimny, another Norwegian
Seems I get delayed until monday to get the engine in.. the flywheel bearing came out in pieces. Probably because I forgot to put a jack under the gearbox before pulling the engine apart from the box, tearing the bearing off.
Been all over the city looking for a bearing, but the shops that could have it are closed on saturday, of course.
Guess I can take my time getting everything ready, have to patch some rust holes also at the front thats not reachable when the radiator is in.
Here is the blanking plate for the rear of the head. Original with a rubber seal, metal gasket on the Baleno G16B. Sealed a little bit with rtv silicone also
- OlaGB
12 May 2018 11:08 #192617
by OlaGB
Replied by OlaGB on topic Re:My 01 Jimny, another Norwegian
Good job so far.. I actually find it easier to just remove the gearbox before pulling out the motor, but ofcourse not as easy when the car is on the floor.
Did you check the flywheel for wear, as it looked alittle worn on the pictures?
- MadsV
12 May 2018 11:16 #192618
by MadsV
It will do for now :lol:
The clutch has had its days so I should consider changing the flywheel later on
- MadsV
12 May 2018 12:10 #192620
by MadsV
- MadsV
12 May 2018 14:30 #192621
by MadsV
Time to create page: 0.378 seconds
