My Jimny named R&B
04 Apr 2021 13:23 - 24 Aug 2021 07:57 #234224 by jackonlyjack
Replied by jackonlyjack on topic My Jimny named R&B
After all final checks I went for a drive
This setup may not be for everyone
Super soft.
Parts used 1" spring spacer (front drivers side)
4 rear Honda crv springs 1995-2001
SUP 011076
KYB RC5814
KILEN 54014
1 complete coil needs cutting off for rears
I took it from bottom
Shocks were from vit-mods +3"
Note I had to use my old Bush sleeves
Ones in shocks are a little to long (could be cut down)
Up Travel to bump stops 4.5" front rear 5" (leaving around 1" left on shock up travel)
Down travel they go far enough for springs to fall out
Spring clamps been ordered
I cannot say how much lift it gives as I didn't measure
I would guess ~3"
Last edit: 24 Aug 2021 07:57 by jackonlyjack.
04 Apr 2021 15:47 #234229 by Lambert
Replied by Lambert on topic My Jimny named R&B
When you say soft what are you talking, compliant off road but still drives ish on road or so soft it's oft road only? Still cool either way.
The following user(s) said Thank You: jackonlyjack
04 Apr 2021 16:13 #234232 by jackonlyjack
It feels a little floaty drives over speed bumps well
Gives a lot of body roll on corners (no arb fitted)
Not had chance to try off road but should get good articulation (or fall over)
cost me less than 200
Might save and get 4 adjustable shocks i'm happy with how soft the springs are
  • Groundworker
04 Apr 2021 16:52 #234234 by Groundworker
Replied by Groundworker on topic My Jimny named R&B
Have you done anything about castor correction? Looking to replace my trialled so need suspension set up, soft sounds brilliant for what I want. Did you cut spring down because it was too long?
04 Apr 2021 17:10 #234236 by jackonlyjack
I was already running +3" castor arms all round
Yes chopped off coil to make it sit level
Groundworker you may need to chop more off to suit your truck
04 Apr 2021 17:28 #234237 by Lambert
So sort of mk1 range rover soft then. Cool.
Time to create page: 0.198 seconds
