My Jimny named Grin Giver
23 Jun 2020 06:53 #223891
by kirkynut
Replied by kirkynut on topic My Jimny named R&B
If you're anywhere near Sussex, Rhino Ray will make a cage for a reasonable price I believe.
A friend did mine for me in South Essex.
Topic Author
30 Jun 2020 16:16 #224293
Replied by jackonlyjack on topic My Jimny named R&B
Time for front axle strip down
Paint my swivel's
Trailgear shafts n cv's
26 spline side gears
And new kingpin bearings if needed
Paint my swivel's
Topic Author
26 Jul 2020 15:06 - 07 Aug 2020 07:36 #225702
Por15 on the swivel's
Modified landy engine mounts to fit transfer cradle
Measurements
X2 cut to fit driver side
This one cut and shaped to fit rockwatt cradle
Not sure you would need to modify for standard transfer mounts
Measurements
Last edit: 07 Aug 2020 07:36 by kirkynut.
Topic Author
29 Jul 2020 18:20 #225831
Modified bushes fitted
While i was under their had a look at rear engine mount
Central bolt looked off to oneside
So got a new one from the spares shelf
Old one not delaminated but rubber really soft
30 Jul 2020 17:02 #225864
Replied by Riccy on topic My Jimny named R&B
They look a good fit
The following user(s) said Thank You: jackonlyjack
Topic Author
30 Jul 2020 18:18 #225871
They do fit well Riccy
Got fed up of the bolt through one's moving to one side slightly. think that's due to the bolt through's only being M8
Landy one's are M10 so no movement to be had,the transfer is lifted around 15mm higher up now
Expecting some vibration from them....but knowing they are now super strong i can live with vibration :laugh:
Time to create page: 0.418 seconds
