Project Rust bucket
  • thompo
11 years 4 months ago - 11 years 4 months ago #146550 by thompo
Project Rust bucket was created by thompo
Following on from my queries on how to fix it ( www.bigjimny.com/index.php/forum?view=to...=7&id=55843&start=12 ) ive finally found some time to put up my thread. :)
Here it is back in Nov 2014, just purchased with the understanding it needs some minor welding for MOT. All i have to do now is drive it 250miles to get a 3Hr ferry crossing in torrential rain and gale force winds :)
Got it home and stripped the rear out to see what we were dealing with and what it would cost to have it welded...
Needless to say this was the tip of the iceberg!
After some digging i came to conclusion that i wouldnt be paying someone to fix it and id be learning some new skills lol.
This bit just fell off when i removed the bumper
Body mount holed and mounts no longer attached to body
Front end rotten too
Most of the bad stuff removed from the back
Plan of attack was devised,
Aquire a mig welder uncle had hobby spec SIP150 that he never used prefering Oxy/Aceteylne brazing/welding
Learn to weld a little
Repair chassis mount
Repair/ replace body mounts
2.5mm box section with 3mm angles plug welded internally to rear pillars/door frame (double/triple skin areas), remenants of rear panel and internal rear arches rebuilt with 2mm plate and welded to box section. Finally 5mm steel plates with original mount posts welded on. Seems to have worked fine.
Put in new Metal where required.
My method
Area to replace
Clean and remove until you hit solid metal
Repair the easy bits
Template the more difficult
Weld it up
Boot floor/arches patched, Fully down both sides, new jack recess made, lots of new metal added in.
Looks straight forward written here lol
So finally after 3 weeks of grinding, welding, cutting and 3 stitches in my knee due to "grinder incident" it was ready for MOT....
Or so i thought! as id been preoccupied with adding new metal back in id forgot to check normal stuff! Turns out driver side king pin bearing was shot.
It didnt fail to live up to its name of Rust Bucket! Every nut and bolt disentigrated! im not kidding when i say i think i managed to get 1 bolt out using the standard size socket, every other bolt had an undersize socket hammered on, vice grips used or when all of that failed (maybe 6bolts) i had to weld something onto them to get some heat into them and give vice grips some purchase then keep the heat on with a blow torch to finally remove them.
Some 3 hrs later i had 1 side stripped! 20mins later it was back together with new bolts :)
So MOT then :)
:( - at least it didnt fail on any of the stuff i had done :)
Dodgy sill
Suspected crack in chassis - turned out to be surface rust on a previous repair, was cleaned up and seemed sound
so more welding - 3mm plate welded into section of chassis that was looking suspect.
Minor fire
due to hole in floor whilst welding sill
more welding
All done -
I actually forgot to take a picture once everything was sealed and painted before the interior went back in :(
Thankfully it passed MOT this time
So it had its first outing that weekend
With the Mutt who was the main reason for buying the jimny or so the wife could drive it in the snow
Not sure he gets how its meant to work though!
and a few more
First Mod, 16" Grand Vitara wheels and 205/80/16 Insa Dakars seems to be around 29"
Even got some Snow to try them on
Some underbody protection made up - seems a sin to use 10mm Carbon Fiber plate for bashing on rocks but its all we had in the work scrap bin that would do. Interesting to see how long it lasts.
Deffo easier to weld the 6mm brackets up for the transfer box guard than the 1.2mm for body work.
Test fit - Bolts were all properly orientated for final fit.
Ready for some fun
Got a couple further mods done (discreet winch and body lift) ill post when i get time again.
Last edit: 11 years 4 months ago by thompo.
  • minibbb
11 years 4 months ago #146553 by minibbb
Replied by minibbb on topic Re:Project Rust bucket
Bloody hell! That was a project and a half!!
Cracking job though- many (including me) would have given up on it!!
Looking great now and is the best of the Jimny colours!
11 years 4 months ago #146562 by kirkynut
Replied by kirkynut on topic Re:Project Rust bucket
Crickey! That was a scrapper in my mind! Well it was before you learnt to weld!
What an awesome job you've done!
Did you get a new door card and seat after the minor fire? There's a lesson learnt there I guess!
  • Tadpole
11 years 4 months ago #146568 by Tadpole
Replied by Tadpole on topic Project Rust bucket
Thanks for sharing 10 out of ten for sticking with it ...... :ohmy:
  • markyp2000
11 years 4 months ago #146592 by markyp2000
Replied by markyp2000 on topic Project Rust bucket
A good job well done but you didnt need to undo the 4 bolts behind the hub 100% for effort
  • Daft Waders
11 years 4 months ago - 11 years 4 months ago #146595 by Daft Waders
Replied by Daft Waders on topic Project Rust bucket
Good job your handy with that mig welder B) , hate to think what that would have cost you otherwise ££££
Minor fire
Damn that would have pissed me off, now you can get even less in them silly door pockets :lol:
Last edit: 11 years 4 months ago by Daft Waders.
Time to create page: 0.133 seconds
