Little "Ooky"
14 Apr 2009 19:39 #595 by kirkynut
I also noticed your tow bar sticks out a long way and will restrict your departure angle. Mine is a different design whereby the ball bolts onto a fixed point as normal, I think yours is the one that dismantles a bit.
It might be worth while keeping an eye on ebay for a normal old style one and then getting a Dixon Bate tow hitch to use as your rear tow point, rather than the original tow points or risking the rope flying off the ball on the tow ball.
Looking good though!!!
15 Apr 2009 05:10 - 15 Apr 2009 05:11 #596 by mlines
If your standard breathers are clean then they seem to function ok, with the little cap/spring opening/closing as appropriate. Its once you have done some serious mud work that they clog up and no longer work letting water in or forcing oil out through the gaskets. The axle breather were done on mine but the gearbox and transfer box ones were not. I recently fitted some when I had the gearbox and transfer box off, but a check showed that water had not entered the boxes anyway and the breathers were still working despite everything that off-raoding since 2003 has thrown at the car.
The other popular method is to bring all the breathers together using tee-pieces under the bonnet and then feed a master pipe up into the snorkel tube or up to the snorkel head. But of course you need a snorkel to do this - oh wait - you have one from my favourite dealer!
P.S - may be out on Salisbury Plain in June on the CSMA "Fathers Day" 4x4 treasure hunt.
Last edit: 15 Apr 2009 05:11 by mlines.
  • ooky_123
16 Apr 2009 06:45 #599 by ooky_123
Replied by ooky_123 on topic Re:Ooky's new boots ... almost there !!!
Yes, the Tow bar is a removable one. The complete drawbar is removable. We keep it on because it offers a little more persuasion to anyone that things about tailgating as it would do serious damage if someone were to run into it !!.
to be honest, none of the obsticles have represented an issue with it being left on, but I agree, it does reduce the departure angle ( usually it just digs a groove as it goes!! )
We wanted a standard Plate style one but this one only cost £30 and is a genuine Suzuki Witter one (rrp about £300 !!! ) Plus it makes an excellent standing point to clean the roof :)
With regard to the Axel breathers, we checked the diff oils and they appear to be clean and waterfree so I guess for the moment they are working fine. However in the summer, im sure Hubby will put extension pipes on them.
Yes a manifold assembly will be used, as a pretty and neat engine bay is essential too :)
We plan on replacing the hub bearings and getting the whole 4wd system serviced in the comming months, but for the time being, were going to use it .. if one should fail or show symptons of excessive wear in the short term .... well get them done as and when, but thanks for the comments and recommendations, all advice is greatly recieved and taken on board ( actyually the emails are printed off and kept in a "how to" folder in the garage, and when we get around to it, we will probably laminate them B)
  • ooky_123
28 Nov 2010 15:41 #6676 by ooky_123
Just to resurect this... Now the Snorkel and the body lift has been fitted, so have the avel breathers and the 30mm spacers.
Had to modify the bottom of the wheel arches with the trusty angle grinder.
A few pix attached.
Attachment IMG_2762.JPG not found
Attachment IMG_2761.JPG not found
Attachment IMG_2764.JPG not found
Attachment IMG_2765.JPG not found
  • ooky_123
28 Nov 2010 15:46 #6677 by ooky_123
Also a few of the new roof lights
Attachment IMG_2766.JPG not found
Attachment IMG_2768.JPG not found
Attachment IMG_2767.JPG not found
  • darthloachie
29 Nov 2010 08:34 #6741 by darthloachie
Replied by darthloachie on topic Re:Ooky's new boots ... almost there !!!
my eyes .... it burns ... turn em off .... it burns :silly:
B)
Time to create page: 0.860 seconds
