My O2
  • JimnySweep
  • Visitor
  • Visitor
23 Jun 2013 14:58 #74786 by JimnySweep
Replied by JimnySweep on topic My O2
markyp2000 wrote: The gear box will turn the lay shaft but not the input shaft on the clutch end
Not towing it is some thing to do with the t box and it being 4wd but if its been tryed and tested by othere with no problem then its up to the owner
You're right markyp2000 :) There's a lot of bits of well meaning advice on forums much of which is based on opinions, and what has been read and repeated from elsewhere - very little that can be relied on as fact. Even manufacturers can ere on the cautious side to avoid problems from customers at a later date. Some warnings related to bearings, some to transfer boxes, some to transfer casings others to gearboxes.....
I did a lot of research into this and am no stranger to 4x4s, gearboxes and other mechanicals, mind you I'm not claiming to be some sort of expert either. The advice I chose to take was from those who have actually been there and done that.
Now it may be that I'll be back on here at some later date reporting a problem some miles down the road, then it will be results based on my own experience :dry:
I'll be older and wiser if that happens :)
  • helijohn
  • Visitor
  • Visitor
23 Jun 2013 19:24 #74834 by helijohn
Replied by helijohn on topic My O2
The SJ used to be tugged along by a number of folks. I looked into this when I was going to move house years ago but in the end I bought a short trailer for it. Someone had made it out of caravan chassis especially for the SJ.
  • JimnySweep
  • Visitor
  • Visitor
23 Jun 2013 19:37 #74843 by JimnySweep
Hi helijohn, a trailer of some sorts was one of the considered options for taking a car along with a motorhome on travels. The problem was that of storage when not needed - hence the decision to go down the a-frame route, which simply folds and stores in one of the motorhome's lockers.
  • helijohn
  • Visitor
  • Visitor
23 Jun 2013 20:16 #74851 by helijohn
JimnySweep wrote: Hi helijohn, a trailer of some sorts was one of the considered options for taking a car along with a motorhome on travels. The problem was that of storage when not needed - hence the decision to go down the a-frame route, which simply folds and stores in one of the motorhome's lockers.
Yes, totally agree. Even a short trailer can be a nuisance.
Time to create page: 0.132 seconds
