My O2
  • JimnySweep
  • Visitor
  • Visitor
22 Jun 2013 15:44 #74674 by JimnySweep
My O2 was created by JimnySweep
Recently bought my 2003 Jimny to tow behind my motorhome, which gives us a car to use whenever we are in the UK :) . Most of each year we are either touring around Europe or house based in Spain.
We use an a-frame from Towtal which allows the car to brake proportionally to the motorhome to comply with regulation changes that are due to come into force after 2014.
Anyway, the Jimny is great so far and although its mostly going to be used on-road I'm looking forward to getting back to our Spanish house later in the year and getting up into our local mountains. We use an ageing Isuzu Bighorn out there so it will be interesting to compare their abilities B)
Since buying the car I've changed the graphics and tinted the rear windows
Very tempted by some of the Jinmys on here to start modifying but will be keeping it fairly standard for the time being.
  • iloveics
  • Visitor
  • Visitor
22 Jun 2013 16:20 #74680 by iloveics
Replied by iloveics on topic My O2
Nice jimny, although should you be towing it? theres something in the handbook and door where the tyre pressures are, about not towing it?
  • markyp2000
  • Visitor
  • Visitor
22 Jun 2013 16:27 #74682 by markyp2000
Replied by markyp2000 on topic My O2
iloveics wrote: Nice jimny, although should you be towing it? theres something in the handbook and door where the tyre pressures are, about not towing it?
You are right on that one easyest thing to do is just unbolt the rear prob off the diff
  • JimnySweep
  • Visitor
  • Visitor
22 Jun 2013 16:30 #74684 by JimnySweep
Replied by JimnySweep on topic My O2
I did quite a bit of research before deciding that a Jimny would be suitable and the conclusion was that so long as it was pre 2004 and manual 4 wheel drive selection it is fine for flat towing. This has been reinforced by several motorhomers who have some years of experience.
The owners of Towtal towed a Jimny for several years themselves and raved about it. So I'm quietly confident ;)
  • iloveics
  • Visitor
  • Visitor
22 Jun 2013 16:30 #74685 by iloveics
I don't understand what damage this could cause? how is towing it any different to coasting down a hill for example?
  • adamatdraycott
  • Visitor
  • Visitor
23 Jun 2013 09:23 - 23 Jun 2013 09:27 #74737 by adamatdraycott
Replied by adamatdraycott on topic My O2
Towing with an a-frame the car becomes recognised as a trailer.
A trailer must be braked if over 750k
A jimny curb is 1030kg
How have you hooked you brakes up?
This is the reason you see many motor homes pulling Toyota IQ's as they weigh next to nothing
See this link:
www.gov.uk/towing-with-car/towing-equipment-safety-standards
Last edit: 23 Jun 2013 09:27 by adamatdraycott.
  • JimnySweep
  • Visitor
  • Visitor
23 Jun 2013 10:23 #74740 by JimnySweep
adamatdraycott wrote: Towing with an a-frame the car becomes recognised as a trailer.
See this link:
Certainly have :)
The system I'm using is called RVi2 www.towtal.co.uk/motorhome-a-frames/rvi-brake/
Brilliant bit of kit and easy to set up, does away with the overrun system that is likely to be outlawed after next year.
  • adamatdraycott
  • Visitor
  • Visitor
23 Jun 2013 11:53 #74747 by adamatdraycott
Impressive bit of kit!
  • markyp2000
  • Visitor
  • Visitor
23 Jun 2013 13:20 #74766 by markyp2000
So how does it work with a servo assised system the more you aply the brake with out the engine running the harded the pedel gets and when you want to use it the battery is flat due to jimnys fag lighters only working with the ignition on
  • JimnySweep
  • Visitor
  • Visitor
23 Jun 2013 13:25 #74768 by JimnySweep
It doesn't rely on the servo, when setting up the kit pumps the pedal a few times to bleed it. There is enough strength in the mechanism to work the brakes without servo assistance.
The cigarette lighter is permanently live on mine so doesn't need to have the ignition on and the current drain is tiny.
  • Northern-Wanderer
  • Visitor
  • Visitor
23 Jun 2013 14:36 #74779 by Northern-Wanderer
Replied by Northern-Wanderer on topic My O2
Suzuki say that as the gearbox is not turning no oil is been splashed onto the rear gearbox bearing that supports the propshaft and over a long distance of towing the bearing will run dry.Markyp2000 is right,take off the prop for long distance towing
  • markyp2000
  • Visitor
  • Visitor
23 Jun 2013 14:44 #74781 by markyp2000
The gear box will turn the lay shaft but not the input shaft on the clutch end
Not towing it is some thing to do with the t box and it being 4wd but if its been tryed and tested by othere with no problem then its up to the owner
Time to create page: 0.170 seconds
