Rolling project erm.....
  • Mister Stu
  • Visitor
  • Visitor
03 Feb 2014 23:06 - 03 Feb 2014 23:08 #103277 by Mister Stu
Replied by Mister Stu on topic Rolling project erm.....
Loads done since the last update
painting bits
[IMG
[IMG
Cutting for the next bit B)
[IMG
[IMG
taken off braced and fully welded ready for paint
[IMG
also had a big box delivered from Rockwatt B)
[IMG
[IMG
[IMG
also got alot of the bodywork done so it wont be long now B)
Last edit: 03 Feb 2014 23:08 by Mister Stu.
  • Tadpole
  • Visitor
  • Visitor
04 Feb 2014 09:51 #103312 by Tadpole
Replied by Tadpole on topic Rolling project erm.....
Some real progress made for sure .............. ;)
  • craigy123
  • Visitor
  • Visitor
04 Feb 2014 10:32 #103314 by craigy123
Replied by craigy123 on topic Rolling project erm.....
Looking good mate. I've just started to do mine last week. Hopefully will be at this stage soon. What diameter and thickness of steel are you using for the cage?
  • Mister Stu
  • Visitor
  • Visitor
04 Feb 2014 11:09 #103318 by Mister Stu
The tube is 2" O/D with a 3mm wall, i was going for blue band seamless but its only a laner and couldnt justify the money :blush: RW transferbox is painted up along with the cradle and ready to go in but still havent managed to source a SJ mid and front prop to fit.. back axle is all painted ready to be fitted after the arms and bushes get here
Then do the front :whistle:
list of things to do
-mount winch in the tray and wire in
-tart up both axles and refit
-wire in rear lights and spot lights
-paint paint paint paint paint
  • craigy123
  • Visitor
  • Visitor
04 Feb 2014 12:43 #103325 by craigy123
There's a guy on eBay selling the props you need. £95 for both delivered I was quoted!!!
rover.ebay.com/rover/0/e11051.m66.l1181/...AX%3ARTQ%3AGB%3A1181
04 Feb 2014 14:38 #103339 by j999pre
Replied by j999pre on topic Rolling project erm.....
Mister Stu wrote: The tube is 2" O/D with a 3mm wall, i was going for blue band seamless but its only a laner and couldnt justify the money :blush: RW transferbox is painted up along with the cradle and ready to go in but still havent managed to source a SJ mid and front prop to fit.. back axle is all painted ready to be fitted after the arms and bushes get here
I have a sj front prop if your looking?
Grey pick up Jimny
  • Mister Stu
  • Visitor
  • Visitor
04 Feb 2014 16:53 #103366 by Mister Stu
I need a front and the middle props off a 413/sammy.. what would you be asking for it?
  • Yellostreak
  • Visitor
  • Visitor
04 Feb 2014 17:41 #103371 by Yellostreak
Replied by Yellostreak on topic Rolling project erm.....
I ended up putting a 1/2" spacer in the 'mid-prop' when I fitted my Rockwatt box and cradle as the output from the main gearbox was out by a little way.. works great though I'm well chuffed with his stuff.
04 Feb 2014 17:54 - 04 Feb 2014 19:48 #103372 by j999pre
My sj prop is the 8mm bolt one with slightly narrower spacing than the big 10mm versions. Depending on what flanges you have you can swap ends or may have to re-drill flanges suit. My lobster had a mix of flanges so i swapped the small end from the jimny front prop with the small end on the sj to match up. I would have only needed to drill my rear diffs then but needed a new uj, so i swapped that end for the one on the jimny rear prop so it all matched up.
Grey pick up Jimny
Last edit: 04 Feb 2014 19:48 by j999pre.
  • Mister Stu
  • Visitor
  • Visitor
04 Feb 2014 19:45 #103391 by Mister Stu
Im pretty sure rockwatt said that the box has correctly drilled flanges ;) il have a measure up
  • Mister Stu
  • Visitor
  • Visitor
12 Feb 2014 22:03 #104326 by Mister Stu
Been spending again :laugh:
-bush set
-4 arms
-h/d tb mounts
-prop spacer
-new radius arm bolts
-6 micro spotlights for the cage, 4 forward facing and 2 rearward
[IMG
  • markyp2000
  • Visitor
  • Visitor
12 Feb 2014 23:14 #104334 by markyp2000
Replied by markyp2000 on topic Rolling project erm.....
Looks good but id send them spot lights back i had them on mine id of been better off holding a candle lol
