jimny progress
24 Jun 2012 18:58 #42835 by robs5230
jimny progress was created by robs5230
had the jimny about 2 months now and removed all the mods i didn't want.
out with :
winch , cb
in with :
new shock bushes all round
insa turbo dakar tyres
aisin manual hubs
rear shock relocation brackets
i tried today to install the spacer to cure the lean but the axle just wouldn't drop far enough. need to get spring spacers. running well considering the lift , tyres etc . doing around 200 miles per tank.
been in touch with KAP suzuki. they have confirmed its a vehicle done by them a while ago :cheer:
all in all , lovin' it. its gonna be around a long time. does everything i need of a motor.
the manual hubs have made a big difference ( must have been dragging a sticky vac hub around ) no noises now and believe it or not its faster now :huh:
standard jimny - for now
  • markyp2000
24 Jun 2012 19:18 #42837 by markyp2000
Replied by markyp2000 on topic Re: jimny progress
you may have done this but did you undo the lower shock mount on both sides and jack the chassis up i have trouble getting my axles to hang i just brought a hi lift farm jack and some axle stands that are 24" at there lowest point
  • myers647
24 Jun 2012 19:43 #42839 by myers647
Replied by myers647 on topic Re: jimny progress
Hi mate off subject but you said you have removed the CB? what you doing with it and does it work because Im after one.
Thanks
James
24 Jun 2012 20:01 #42841 by robs5230
Replied by robs5230 on topic Re: jimny progress
bugger ! only undid the shock bolt on the drivers side . never thought the other side needed to go up
as for the cb , sorry sold it
  • markyp2000
24 Jun 2012 22:39 #42865 by markyp2000
you may have to take the front calipers off to so as not to stretch the brake pipe also helps the axle to drop lower
25 Jun 2012 05:53 #42871 by robs5230
got that one covered :) goodridge extended hoses.
