Sandez's Jimny from Aus
- HiJim
- Visitor
If i put 235's on my jimny (1999 JLX 5 spd manual). Will i need to change the gearing?
- Black Toy
- Visitor
any modifications to fit?
thankss
- Sandez
- Visitor
I haven't needed to because the auto compensates, but I found a bit lack of power when cruising on the freeway so I'm still contemplating gearing. Given the shorter ratios for a manual, I would probs recommend you plan for gearing, if you get the 235s and find that you can live with less power then its a bonus. I think most have said that its the low range crawling that is affected the most, having to slip the clutch alotHiJim wrote: If i put 235's on my jimny (1999 JLX 5 spd manual). Will i need to change the gearing?
- Black Toy
- Visitor
I only have two options of wheels locally if i'm gonna mount 235s:
15x8 -13 and 15x8 -25
Any experience with that? Thanks
- HiJim
- Visitor
With the offset on your wheels how far away from the guards are your tyres?
I wanted to put some 235/75/15 muddies on 15x7 rims but wasnt sure what offset i should get the wheels at to make the tyres just at the guards or slightly over.
Thanks,
HiJim
- Sandez
- Visitor
Sorry mate, can't help you out there, tho -13 8" shouldn't stick out any further than the 7" so it should fit fine. If you go for the -25 you might have issues with it scrubbing on the rears as it sticks out further, see my pics on first page here to see how close it is already, but I wasn't checking on that. Others might have already done it without issues so it might by worthwhile starting a thread on it. After all, an extra 12 would make it more stable again.Black Toy wrote: I only have two options of wheels locally if i'm gonna mount 235s:
I've gone for -13 and they fit in perfectly and tuck up nicely without having to cut anything cept the front bumper, with -25 as I mentioned above, you might need to trim the inside of the lip to prevent any scraping, but you might want to start a thread to find out if others have done it and found any issuesHiJim wrote: With the offset on your wheels how far away from the guards are your tyres?
