Sandez's Jimny from Aus
- Sandez
- Visitor
06 Feb 2012 06:26 - 06 May 2012 13:24 #32803
by Sandez
Sandez's Jimny from Aus was created by Sandez
Hi Guys,
Thought I would finally share my Jimny, my second one.
Its a 2007 model Automatic with 80k on the clock. Have only had it for a month. There hasnt been any major mods done yet, but will be shortly once JB gets some more stock. The list is big enough and still growing. The plan is to turn the beast into a nice go anywhere touring vehicle for myself, but still a daily driver to and from work.
Current mods:
[strike]205/75/15 Toyo A/T tyres[/strike] 235/75/15 Federal Couragia 15" -13 Offset Black steel rims
GME TX 3100 UHF Radio - Window aerial (To be replaced in the near future)
Tinting
Rear seats removed and [strike]flat tray installed[/strike] cargo drawers
Steering dampener
4x 3UP 10w LED Spotlights ( Build guide here )
Adjustable panhard rods
3" RoughCountry Lift kit
Extended brake lines
iPad mount with OBDII connection
Near future mods:
Castor correction bushes
Front and rear recovery points
Diff, Trans and Gearbox breathers
Future mods:
2" Exhaust with extractors
Lockright Rear locker
Sway bar disconnect
Engine bay mounted air compressor
So enough talk, here are the pics.
In its current up-to-date state 6-May-12
Purchase
Next to my old '01 Jimny
Spotlights installed
Spotlight beamshot on the beach
My attempts at playing with the camera
More pictures to come as the mods are done.
Enjoy!
Current mods:
Tinting
Steering dampener
Near future mods:
Future mods:
Sway bar disconnect
Purchase
Attachment PrePurchase.jpg not found
Attachment Comparison.jpg not found
Attachment Spotlights.jpg not found
Attachment SpotlightsBeam.jpg not found
Enjoy!
Last edit: 06 May 2012 13:24 by Sandez.
- w0ut69
- Visitor
06 Feb 2012 16:05 #32834
by w0ut69
Replied by w0ut69 on topic Re: Sandez's Jimny from Aus
Nice and clean Jimny !!
- zukenutter
- Visitor
11 Feb 2012 09:31 #33244
by zukenutter
Replied by zukenutter on topic Re: Sandez's Jimny from Aus
Swapping over from another Jimny is fun. I swapped all my mods from my 2001 Jimny to my 2006 about 15 months ago.
How does your cooling system cope during summer with those spot lights blocking air flow?
- Sandez
- Visitor
23 Feb 2012 22:11 #34094
by Sandez
Well Ive ordered the 3" RC Lift, adjustable panhards, castor bushes, brake lines, diff/trans/gearbox breathers, OBDII connector and I have begun construction of the rear drawers. It should all come together nice and quick and to a stage where I am happy with it and can start doing some serious weekenders.
Ill be sure to take plenty of pics to keep you all happy
Replied by Sandez on topic Re: Sandez's Jimny from Aus
Havent had any issues with cooling. Could be because the air can still get through the big vent in the bumper, if I had a bullbar I might be running into trouble.zukenutter wrote: How does your cooling system cope during summer with those spot lights blocking air flow?
- Sam_
- Visitor
24 Feb 2012 14:34 #34129
by Sam_
Replied by Sam_ on topic Re: Sandez's Jimny from Aus
Be very interested in how you do the draws as once I get one I'm planning something similar.
- Sandez
- Visitor
24 Feb 2012 19:51 - 06 May 2012 13:15 #34150
by Sandez
The end result of the drawers should be something similar to this. The whole system is going to be made out of wood because I have most of it lying around, not using the aluminum framing and joins as I designed in the pictures, but the layout is going to be the same nevertheless
It has a small pocket that I can reach from the drivers seat (seen in pic 2) and Ill have 2 6x9 speakers next to them to give some better sound
Last edit: 06 May 2012 13:15 by Sandez. Reason: Fix photo links
