My jimny from devon
- r_ogilvy
- Visitor
18 Nov 2011 12:11 #26014
by r_ogilvy
Replied by r_ogilvy on topic Re: My jimny from devon
Yeah it was a good brushed up against a tree so have a few scares now, hopefully the cage will prevent that.
Iv started it so I will have both sat and sunday on it, I will do a few pics tomorrow!
- supergaz
- Visitor
18 Nov 2011 17:11 #26024
by supergaz
Replied by supergaz on topic Re: My jimny from devon
Great pictures! Keep them coming.
- r_ogilvy
- Visitor
19 Nov 2011 17:12 #26108
by r_ogilvy
roll progress, rear bend is a bit wide but il be short on tube if i didnt use it
should be a bit better if i roll.
please comment i can take bad comments;) i would rather closer to the body but best i can do with what i have
Attachment Hydraulic-Pipe-Bender.jpg not found
Attachment rollcage007.jpg not found
Attachment rollcage005.jpg not found
Attachment rollcage006.jpg not found
Attachment rollcage009.jpg not found
Attachment rollcage013.jpg not found
Attachment rollcage012.jpg not found
Attachment rollcage002.jpg not found
19 Nov 2011 19:02 #26117
Replied by mlines on topic Re: My jimny from devon
Does that pipe Bender do 25mm tube? (yes I do mean 25mm)
Sent from my HTC EVO 3D X515m using Tapatalk
- r_ogilvy
- Visitor
19 Nov 2011 19:12 #26119
by r_ogilvy
its got formers for 20mm, iv bent 30mm ok by packing the tube with sand and taping the ends.
iv had to fill all my tubes with sand tho to get a good bend
i did have to pack the formers for a tight fit.
19 Nov 2011 19:18 #26121
Ok, I was looking for something to bend 25mm stainless thick wall for the cover for my boat
- r_ogilvy
- Visitor
19 Nov 2011 19:23 #26122
by r_ogilvy
i have used different pipe for little things and its kinked before, so i wouldnt like to say on stainless.
- supergaz
- Visitor
19 Nov 2011 19:26 #26124
by supergaz
Have you tried the springs that plumbers use? It stops the kinks.
- r_ogilvy
- Visitor
19 Nov 2011 19:36 #26126
by r_ogilvy
iv never tried them, i use kiln dried sand and keep tapping it down.
would i get away with using 44 mm pipe like the roll cage for a snorkel, or is it to small and starve the engine?
- Cider
- Visitor
19 Nov 2011 20:56 #26137
by Cider
Replied by Cider on topic Re: My jimny from devon
Been around to have a look today and it`s a "proper Job."
Great job done. Rich
Cheers
Pete
Cheers
Pete
- X-Eng Simon
- Visitor
19 Nov 2011 21:07 #26140
by X-Eng Simon
Replied by X-Eng Simon on topic Re: My jimny from devon
Martin, I have a 1" former for my JD2 if it's any use?
Si
Si
- r_ogilvy
- Visitor
20 Nov 2011 16:11 #26176
by r_ogilvy
a little more work today took it off so i could weld it fully up.
just need to paint it!
r_ogilvy
Attachment rollcage2002.jpg not found
Attachment rollcage2001.jpg not found
r_ogilvy
Time to create page: 0.267 seconds
