JK's Jimny - Tasmania - Australia M18A, Manual with Auto Transfer and 30" KM2's
  • jaykay
  • Visitor
  • Visitor
21 Oct 2013 23:49 #87441 by jaykay
Had some work done to my rusting roof basket.
Patched up, extended slightly to fit swag, and resprayed.
also mounted up this bad boy. :idea:
Photo doesn't do the brightness justice
  • Jonno_racing
  • Visitor
  • Visitor
22 Oct 2013 12:08 #87481 by Jonno_racing
Replied by Jonno_racing on topic JK's Jimny - Tasmania - Australia Rolling on 30's
We need to do some wheeling together and get gricey along forcsone group pics
  • jaykay
  • Visitor
  • Visitor
22 Oct 2013 19:20 #87534 by jaykay
Jonno_racing wrote: We need to do some wheeling together and get gricey along forcsone group pics
I agree
  • MRocha
  • Visitor
  • Visitor
24 Oct 2013 21:25 #87820 by MRocha
your jimny is getting better, continue the good work.
in your roof rack you have an awning fitted and what else?
  • jaykay
  • Visitor
  • Visitor
24 Oct 2013 22:01 #87828 by jaykay
MRocha wrote: your jimny is getting better, continue the good work.
Thanks mate, I also have a Rod tube on the other side usually - but its been taken off while I got repairs on the basket done.
  • jaykay
  • Visitor
  • Visitor
20 Jan 2014 11:35 #101244 by jaykay
Haven't updated for a while been having issues with the zooks engine getting too hot.
After replacing the thermostat/ water pump and radiator cap the zook decided that was enough and blew the head gasket.
So time to fill everyone in on the Jim.
First this happened
Top radiator hose split lost coolant and cooked motor ( been over heating for a while now and was in the process of tracking it )
Coming close to the end of my holidays I needed to do something ASAP as the zooks my daily.
And I found this !
Then this happened
This is the result of trying to get the crank bolt out with a socket and a long handle - bench gave way
Got the motor in, missed a earth so had to trace back and find it.
Started her sat night n did a quick lap all was good.
Sunday this happened
O ring split on an injector ( used 1.3 instead of 1.8 injectors so just swapped them to the 1.8 )
Fixed, not viscus fan has died new ones on order !
  • jonesyba420
  • Visitor
  • Visitor
20 Jan 2014 14:05 #101259 by jonesyba420
Replied by jonesyba420 on topic JK's Jimny - Tasmania - Australia Rolling on 30's
i wish my engine was that clean lol!!!!
  • jaykay
  • Visitor
  • Visitor
21 Jan 2014 00:33 #101403 by jaykay
Wont be so clean once I wheel it !
have a few other mods to do before I do a trip.
Bullbar needs a chop chop and also going to extend my rear bump stops a bit.
23 Jan 2014 11:47 #101679 by kirkynut
This has turned into an awesome Jimjam!
It amazes me how you Aussies get out there so much and do it, I need to get off my backside and get out in the UK a lot more!
Was the viscous the cause of the overheating?
I have a scanguage in mine do I can see what the exact temperature is, the car's guage doesn't go up past half way until it's really hot!
  • jaykay
  • Visitor
  • Visitor
23 Jan 2014 20:31 #101743 by jaykay
Cheers mate, the viscus fan defiantly contributed and was eventually the final nail in the coffin.
I bought a WIFI OBD scan tool which I can connect to my iphone.
I watched the temprature on a 30min highway drive last night.
The coolant rose to 97-101 degrees then dropped back to around 90 degrees and stayed there which tells me everything must be working.
The 1.8 on the highway is awesome first time I've ever overtaken cars up hill !
23 Jan 2014 20:58 #101747 by kirkynut
Sounds good then!
My twin cam 1.3 Jimny never really goes above 97'c on a long uphill stretch of motorway in our summer, but my 1.5 Ignis Sport can go to 98-99'c in the summer if I'm on a long uphill climb on a motorway.
Have a check of your radiator too as I found mine was clogged and it sat at 104'c on a long uphill climb on a motorway. I couldn't clean it out enough to be happy so bought a new one to be on the safe side.
I would just keep an eye on it for a while and perhaps invest in a scanguage that can be permanently plugged in, so you don't have to think about connecting your phone interface bits. It's always there at a glance then to spot early on any trouble as you get to know what temperature it ought to be in differing circumstances.
Something positive came from you frying your 1.3 though eh!
  • jaykay
  • Visitor
  • Visitor
16 Apr 2014 01:57 #112310 by jaykay
Sorry I havent updated for a while.
zooks been off the road for nearly a month.
I recently had a 4wd trip with a Magazine here in Aus called 4WD Action
heres a few pics
[img
[img
[img
[img
[img
[img
[img
[img
