Re:Aussie 2006 Jimny - 4" lift, 30" BFGs, cool wheels
  • Monkey
23 May 2011 09:10 #16818 by Monkey
Replied by Monkey on topic Re: Aussie 2000 Jimny
Looking good mate!
  • renard38
23 May 2011 14:56 #16851 by renard38
Replied by renard38 on topic Re: Aussie 2000 Jimny
why did you change the rear driveshaft??? :huh: ( I have the same at the beginning with my new transfert box 4.16 )
  • zukenutter
23 May 2011 19:09 #16869 by zukenutter
Replied by zukenutter on topic Re: Aussie 2000 Jimny
Without going and measuring them, I think the Original shaft is too short. The replacement is an SJ front shaft.
24 May 2011 07:35 #16887 by Obarno
Replied by Obarno on topic Re: Aussie 2000 Jimny
With the ORA kit the original Samurai transfer box rear flange is used and therefore the Jimny prop will not bolt up to it as it is the wrong shape for a CV prop, and also its too short. With the Measson kit you get a new rear output flange which allows the original Jimny prop to bolt straight to the Samurai transfer box and it also corrects the propshaft length issue.
On my rear prop I had an ali spacer/adaptor made that bolts to the Sammi flange but takes an original Jimny prop.
  • zukenutter
24 May 2011 19:13 #16914 by zukenutter
Obarno wrote: With the ORA kit the original Samurai transfer box rear flange is used and therefore the Jimny prop will not bolt up to it as it is the wrong shape for a CV prop, and also its too short. With the Measson kit you get a new rear output flange which allows the original Jimny prop to bolt straight to the Samurai transfer box and it also corrects the propshaft length issue.
Much better explanation than my lame effort. Cheers
  • zukenutter
17 Nov 2011 23:07 #25992 by zukenutter
Have been doing some paving in a townhouse courtyard, filled the trailer with soil and concrete, went to the tip and dumped the rubbish today. For those that think a Jimny won't pull much weight here's the weigh bridge docket. Note the Gross Weight.
As soon as I dumped the 480kg (Nett waste weight) I went and loaded up 500kg of 10mm Concrete mix and three 20kg bags of cement + tools.
Yeah my gears do help, I don't dump the clutch or ride it, she'll happily pull all day long. Wish I could say the same about the mrs.
This will be handy on the job. I plan to set it up so it can be used front or rear.
Dynamic Power 12V 3000LBS / 1361KG Electric Winch With Wireless Remote
Quick Overview
- Super Big Power up to Max. 2400W, 30Kpa
- Powerful 1361kg Pulling Power (will double that with a snatch block, plenty for my needs)
- Portable, with Built-in Carrying Handle and Quick-Attach Mounting Plate
Went out on the 2nd Jimny Driver's Day, camped overnight.
Time to create page: 0.326 seconds
