SJ Transfer Boxes
  • vitara_mad
14 Jan 2011 17:26 #9604 by vitara_mad
Replied by vitara_mad on topic Re: SJ Transfer Boxes
darthloachie wrote: does this mean the front propshaft is still the standard jimny?
yes still uses the standard jimny front prop you just have to make sure you have a large flange fitted on the front output of the transfer box
14 Jan 2011 17:28 - 14 Jan 2011 17:29 #9605 by Obarno
Replied by Obarno on topic Re: SJ Transfer Boxes
Yes - std Jimny prop on front but make sure the transfer box is the large flange type otherwise the prop won't bolt up. Otherwise you have to change the joint on the end for a Samurai one but be ware there are 2 different sizes of UJ. The Jimny uses 25mm uj's as do Japanese built Samurais, but Spanish built Samurais use 23mm uj's!
Added
Sorry our answers overlapped!!
Last edit: 14 Jan 2011 17:29 by Obarno.
  • Jamie
14 Jan 2011 19:07 #9634 by Jamie
Replied by Jamie on topic Re: SJ Transfer Boxes
Shed builders???
  • vitara_mad
14 Jan 2011 19:52 #9650 by vitara_mad
Jamie wrote: Shed builders???
i think that meens people who build them in there garden shed/workshop
nothing wrong with that in my opinion if the job is done to a good standard & its done by a pro that knows what there doing
there is only one that i know of that does it like that
14 Jan 2011 23:06 - 15 Jan 2011 09:26 #9672 by MigCooper
Replied by MigCooper on topic Re: SJ Transfer Boxes
I spent some time already looking at this and it seems that there is a lot of money to spend in this route ... :unsure: I think that to achieve a proper reduction you will need 2 transfer cases, one from a 413 and one from a 410 and then get then to a specialist to make one 1 of the 2.... from my calculations from what I can remember the 413 transfer case was 250 and the 410 was around 400 + plus the "magic work"
So after thinking a lot I think I will go for the XXXXX (Product name removed at the request of the manufacturer)
There website is (LINK removed at the request of the Manufacturer)
Still one month to decide and then something will happen :evil:
Snorkel and plenty of rust to be treated :)
Last edit: 15 Jan 2011 09:26 by mlines.
  • vitara_mad
14 Jan 2011 23:13 - 15 Jan 2011 09:27 #9674 by vitara_mad
MigCooper wrote: I spent some time already looking at this and it seems that there is a lot of money to spend in this route ... :unsure: I think that to achieve a proper reduction you will need 2 transfer cases, one from a 413 and one from a 410 and then get then to a specialist to make one 1 of the 2.... from my calculations from what I can remember the 413 transfer case was 250 and the 410 was around 400 + plus the "magic work"
So after thinking a lot I think I will go for the (Product name removed at the request of the manufacturer). you can check them (Link removed at the request of the manufacturer).
you dont need to buy new transfer box's to get them made into a lobster box just get used ones it cost me £50 for both the 410 & 413 box & then £400 to get them made into a lobster box & the fitting kit only other thing i had to get was the prop shafts so all in it was about £500
or you could just buy everything already done inc the fitting kit & the lobster box from o.r.a or d&g tuning or they might even be more supplyers around
Last edit: 15 Jan 2011 09:27 by mlines.
Time to create page: 0.094 seconds
