SJ Transfer Boxes
  • ooky_123
12 Jan 2011 17:55 #9484 by ooky_123
SJ Transfer Boxes was created by ooky_123
ok, ive seen a few people mentioning swapping the standard Transfer box for an SJ one to get a reduction in gearing instead of goign the rock lobster route..
Can anyone in the know shed some light on this ?
what work is involved ?
what box is required ?
Adapter plates or modified propshafts needed ?
  • zukhunter
12 Jan 2011 17:57 #9485 by zukhunter
Replied by zukhunter on topic Re: SJ Transfer Boxes
check out the how do section
  • vitara_mad
12 Jan 2011 21:03 #9502 by vitara_mad
Replied by vitara_mad on topic Re: SJ Transfer Boxes
you will need to make new mounting arms for starters
use a sammy or 413 front frop for the rear of the jimny
sammy or 413 gearbox to trans box prop
if you want a working speedo you will need to get a gear made that fits behind the rear output flange & a bracket to attach the speedo sensor cus sj has mechanical speedo drive & jimny has electronic speedo
bend the shift lever about a bit
  • g187eev
14 Jan 2011 08:45 #9563 by g187eev
Replied by g187eev on topic Re: SJ Transfer Boxes
There are many kits available, Martin has used one of our very early kits on his Jimny and I'm pretty sure he'll tell you he's happy with it.
We have restructured our price list recently, making many of our Jimny products much more accesable to budget builders.
Our fitting kit is now only £195 + vat... and that includes your brackets, bushes and speed'o adaptor.
There are also many other kits available... D&G Tuning, Rhino Ray... and a few "shed builders" are also offering parts...
(Sorry Martin if this looks like an ad,I just thought someone should point out that there were actually kits available to buy off the shelf)
Rob Butler :)
ORA
14 Jan 2011 09:13 - 14 Jan 2011 09:18 #9565 by mlines
Replied by mlines on topic Re: SJ Transfer Boxes
Rob, no problem, all are welcome.
To further answer Jasons original question. There is not a lot to be gained from just fitting an SJ box. Clearly it is a step on the path to a full Rocklobster conversion ie. you have one SJ box and you have gone through the process of fitting it. However, in terms of ratio reduction its not a big step.
Standard Jimny T-box:
High: 1.32
Low: 2.145
SJ410 box
High: 1.58
Low: 2.51 - 14% reduction more than Jimny Low Ratio
SJ413 box
High: 1.41
Low: 2.27 - 5% reduction more than Jimny Low Ratio
Rocklobster
Low: 4.16 - 49% reduction more than Jimny Low Ratio
Last edit: 14 Jan 2011 09:18 by mlines.
  • darthloachie
14 Jan 2011 15:24 #9582 by darthloachie
Replied by darthloachie on topic Re: SJ Transfer Boxes
vitara_mad wrote: you will need to make new mounting arms for starters
does this mean the front propshaft is still the standard jimny?
Time to create page: 0.218 seconds
