Fitting Castor Correction Bushes To The Rear!!!
- vitara_mad
- Visitor
11 Jan 2011 21:21 #9426
by vitara_mad
www.bigjimny.com/index.php?option=com_ku...11&id=9417&Itemid=75
Replied by vitara_mad on topic Re: Fitting Castor Correction Bushes To The Rear!!!
gazert wrote: Will u sell the bushes and if so how much?
- adamjimny
- Visitor
12 Jan 2011 09:30 #9444
by adamjimny
Replied by adamjimny on topic Re: Fitting Castor Correction Bushes To The Rear!!!
people do it as the axle rotates round the more lift you have and arms/bushes correct this. same principle for front however you dont notice the difference on the rear but im on look out for cheap ora rears too
12 Jan 2011 14:45 - 12 Jan 2011 14:46 #9465
by Obarno
Replied by Obarno on topic Re: Fitting Castor Correction Bushes To The Rear!!!
I had some spare castor correction bushes and fitted them to the rear. It moves the nose of the diff down which is good but also gives you more clearance between the shocks and springs, and keeps the spring straighter.
Last edit: 12 Jan 2011 14:46 by Obarno.
- biggaz
- Visitor
12 Jan 2011 15:42 #9472
by biggaz
Replied by biggaz on topic Re: Fitting Castor Correction Bushes To The Rear!!!
REAR??
I dont have front ones either
- Bigchridy
- Visitor
12 Jan 2011 18:59 #9487
by Bigchridy
Replied by Bigchridy on topic Re: Fitting Castor Correction Bushes To The Rear!!!
Cheers guys. I'll take the rear arms to work and fit the castor corrected bushes. Fitted new bushes to my ora front arms today! Cant wait to get all the lift and arms fitted now. Hopefully I'll get some pics too so I can keep you all up to date on how the Jimny is doing.
Next problem is getting shut of the disco! If any1 is after a bigger 4x4 please let me no. Then I go out to play in the Jimny!!!
- gazert
- Visitor
13 Jan 2011 18:42 #9533
by gazert
Cheers!
Spose I shud read 4 sale section more often!
Replied by gazert on topic Re: Fitting Castor Correction Bushes To The Rear!!!
Cheers!
