Fitting Castor Correction Bushes To The Rear!!!
  • ypvs jimny 350
13 Jan 2011 21:30 - 13 Jan 2011 21:31 #9550 by ypvs jimny 350
Replied by ypvs jimny 350 on topic Re: Fitting Castor Correction Bushes To The Rear!!!
hi all well i had to fit rear ones on mine has the springs were bending out and hitting the shocks and if i put a washer behind the bottom of the shocks to clear the springs. then the pan hard rod would rub on the shocks and mines only got 2" spring lift. all sorted now and the springs sitting lovely and no rubingB)
Last edit: 13 Jan 2011 21:31 by ypvs jimny 350. Reason: spelling crap
  • vitara_mad
13 Jan 2011 21:37 #9552 by vitara_mad
its something ive thought about but decided it would not be worth it but now you got me re-thinking again
ive got a set of poly caster bushes going spare as ive fitted ora front arms but ive heard they dont flex very well (well not as good as standard rubber bushes) is that right
  • ypvs jimny 350
13 Jan 2011 22:04 #9554 by ypvs jimny 350
hi the poly ones dont flex has well but are alot easyer to fit and they last longer.id rather have poly.
  • Bigchridy
13 Jan 2011 22:24 #9555 by Bigchridy
vitara_mad wrote: its something ive thought about but decided it would not be worth it but now you got me re-thinking again
The way I see it if you have them lieing around (as I do) then you may as well fit them!!!:laugh:
  • ypvs jimny 350
13 Jan 2011 23:23 #9557 by ypvs jimny 350
im with bigchridy on this one u might as well fit them if ur keeping ur jimny.
  • vitara_mad
13 Jan 2011 23:26 - 13 Jan 2011 23:36 #9558 by vitara_mad
yes sounds a good plan & as one of my rear bushes needs replacing anyway its a good time as any to get them fitted
i presume they fit in the same way they do on the front like this
Attachment caster_bushes.gif not found
Last edit: 13 Jan 2011 23:36 by vitara_mad. Reason: added pic
Time to create page: 0.207 seconds
