diesel
- CRAIG23
05 Jan 2011 12:25 #8905
by CRAIG23
diesel was created by CRAIG23
hi am just woundering if any one could tell me how 2 fix a diesel engine in my jimny many thanks craig
05 Jan 2011 16:07 - 05 Jan 2011 16:09 #8918
by facade
Replied by facade on topic Re: diesel
First find a diesel engine that will fit in the space.
Get an adaptor plate for the gearbox to couple to it.
Modify the clutch so it works now
Put the engine in modifying engine mounts as required.
Sort out a radiator and couple it up.
Sort the heater piping out.
Modify the exhaust and air filter piping to fit.
Remove the in tank fuel pump and change to a low pressure pump.
Fit a diesel filter/water separator.
Fit stronger front springs to carry the weight.
Fit a battery with higher CCA.
Sort out the ignition so it works with a diesel, likely wire in a different ecu.
About it I think
Personally, I would sell the Jimny and get something with a diesel engine fitted, a Defender 90 is about the best thing I can think of.
You can get a diesel 4x4 Panda but they are expensive, or even import a diesel Jimny.
About it I think
Last edit: 05 Jan 2011 16:09 by facade.
05 Jan 2011 16:39 #8920
by facade
I forgot to say, but these are not strictly fitting issues:
Inform the DVLA of the change of fuel, supplying engine numbers, proof of purchase and proof of fitment. Likely end up with some odd taxation class as there won't be an emissions figure, required for Y plate onwards.
Inform your insurers and see if they will cover it, and how much extra you have to pay.
- biggaz
05 Jan 2011 16:44 - 05 Jan 2011 16:53 #8922
by biggaz
Replied by biggaz on topic Re: diesel
and hope it works
Seriously though, probably not worth it unless you can do everything yourself, including fabricating mounts, plates etc. However just because youve asked "how to fix a diesel engine in a jimny" probably means you dont have the knowledge or equiptment to be able to do it. Not having a go at you!
If money is no object to you, then buy something else anyway.
Last edit: 05 Jan 2011 16:53 by biggaz.
05 Jan 2011 18:51 #8928
by kirkynut
Replied by kirkynut on topic Re: diesel
I have to agree with Bigaz with his comment that if you are having to ask how to do it, you are unlikely to have the knowledge or skills to pull it off.
This is not a pop at you or your abilities but I knew what needed to be done as mentioned above but would not choose to attempt the conversion as I don't have the necessary skills either.
I also agree that if you want a diesel engined off roader you would be better off buying a green oval of some description.
I think a standard Defender 90 300 TDi would be the nearest comparison to a lifted Jimny - oh god I'm getting close to admitting that a Land Rover is good - I'd best stop typing now ...
- biggaz
05 Jan 2011 18:57 #8929
by biggaz
I couldnt afford a GOOD defender, thats why i have a jimny
Time to create page: 0.348 seconds
