Jimny Diagnostics (via OBDII connection)
14 Mar 2026 09:29 #263997 by Lambert
I have literally just ordered the battery add on. All the issues I've had with my Toyota it's finally time to dig in and fix it myself.
We're going to have to start offering north and south diagnostic services to the community at this rate!
Actually genuinely if you are reading this and having problems with your jimny in the north of England give me a shout it'd be rude to keep this facility to myself.
The following user(s) said Thank You: gv42, Soeley
14 Mar 2026 20:29 #264000 by mlines
First actual use today. Changing the steering wheel in James' green gen3.
Before dismantling check the steering position sensor was reporting "0" with everything straight. Then on reassembling checked it was still "0" before tightening. Took a couple of attempts!
And yes if anyone needs something reading and you can drive to me we can take a quick look
14 Mar 2026 21:21 #264001 by Soeley
Which particular model did you get? There are 3 versions of the CRP919X.
15 Mar 2026 07:15 #264002 by mlines
I bought the £242 version (wired OBD2)
15 Mar 2026 08:24 #264003 by Lambert
Likewise but I also have the battery and charging bolt on.
15 Mar 2026 09:08 #264004 by mlines
@Lambert let me know how it goes with the battery add-on, would be interesed in what information it gives.
