Washer pump issues
10 Jan 2026 15:04 #263354 by me101
Washer pump issues was created by me101
Hi, currently in Scotland and the washer jets (front and rear) are not working. They were a bit tempramental but now don't work at all (no noise from the pumps). Gone from inconvenient to dangerous. Wipers still operate as they should (when you pull stalk for water, the wipers set off but no pump). Tried swapping the connectors to the oposite pumps but no difference. Any ideas guys / gals?
Cheers
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
10 Jan 2026 15:48 #263355 by fordem
Replied by fordem on topic Washer pump issues
Do you have power at the pump connections? Is this an electrical issue or a pump issue?
10 Jan 2026 15:49 #263356 by me101
Replied by me101 on topic Washer pump issues
need to get a meter, out camping at moment. just seems odd wipers activate but neither pumps.
11 Jan 2026 01:05 #263360 by fordem
How cold is it at your camp site? Could the pumps be frozen? Are you running plain water in the washer reservoir?
11 Jan 2026 17:26 #263364 by me101
Hi, running neat washer fluid. not temp related, started being intermittent a week o so ago. cheers
15 Jan 2026 09:42 #263404 by me101
Right, back home. No power registering at the connector (either front or rear). Are they on same fuse? Any common failure points?
