M13a engine problem
05 Sep 2025 17:21 #261852
by Marco.87
M13a engine problem was created by Marco.87
Good evening at all... I'm Marco from italy... Unfortunately i have another problem with my 1.3 vvt 2005, m13a engine... Unfortunately, because the ecu don't help me... Zero errors detected... When the car is parked with the engine at minimum revolution, as i push a little bit the accelerator pedal, the engine "grumble" (i hope that google translate help me good with this word)... Over 1200/1500 rpm it run without any problem... Does someone have got a similar problem? I've thinked ignition coils, injectors, but without an error code, i'm not sure... And coils cost original a lot of money, injectors seems to be available only used. Noone have original new denso injectors on stock...
Many thanks for your precious help and advises.
Marco.
Marco.
- Darthblaker7474
- Elite Member
- Thank you received: 37
07 Sep 2025 21:47 #261875
by Darthblaker7474
Replied by Darthblaker7474 on topic M13a engine problem
Just to clarify:
- When the engine is at idle speed (minimum revolution) and the car is not moving, it grumbles (runs rough, sounds like it's going to stall)
- There is NO check engine light on the dashboard/instrument cluster illuminated.
- The car is low on power/struggles when moving.
07 Sep 2025 22:53 #261876
by Marco.87
Replied by Marco.87 on topic M13a engine problem
First and second point are correct, number 3 not at 100%... If i push the accelerator pedal and the engine go over 1200/1500 rpm, it run perfectly. The problem come out only at minimum rev, and not always. It seems as the engine run at 3 cylinders.
08 Sep 2025 07:32 #261878
by facade
Replied by facade on topic M13a engine problem
Start with a compression check. One cylinder could be low.
12 Sep 2025 16:38 - 12 Sep 2025 16:40 #261931
by Marco.87
Problem solved... I've changed ignition coils and cord set today with new ones and the problem seems to be gone...
Last edit: 12 Sep 2025 16:40 by Marco.87.
The following user(s) said Thank You: Darthblaker7474
- Darthblaker7474
- Elite Member
14 Sep 2025 12:22 #261949
by Darthblaker7474
Good to know, I think myself and a load of other owners are having this issue as well.
I've actually got a set of genuine coils I've yet to fit, as the car seems to be behaving at the moment!
Time to create page: 0.153 seconds
