24th August - Noise coming from Jimny 2014 plate
- dirtgambit
31 Aug 2025 07:54 #261797
by dirtgambit
Replied by dirtgambit on topic 24th August - Noise coming from Jimny 2014 plate
Im gonna get the vac hubs off this morning and see if there's an issue there, but what your saying would make sense, a bit of a job for me but ill get my mech to take a look the cars not being used cos I don't want to cause any more damage. cheers.
- dirtgambit
13 Sep 2025 20:44 #261939
by dirtgambit
Hi, Ok looks like im a few steps forward with this issue.
A member posted mentioning taking off the hubs and see if 1 is in and the other is out, this seems to be the case, when I pushed the centre part in of the vac hub, I never get the sound anymore, steering feels great, done 100 miles today and not a sound anywhere.
here's a pic of the hubs
LEFT:
freeimage.host/i/KuH2hn2
RIGHT:
https://freeimage.host/i/KuHf4Og freeimage.host/i/KuHf4Og
So what does this mean? 1 front wheel is engaged during 2wd? I tested going into 4x4, then went back to 2wd, I then got the sound again? and the hubs are in the same configuration as the pics above.
Kind regards
Michael
LEFT:
RIGHT:
Kind regards
Michael
- dirtgambit
14 Sep 2025 07:57 #261940
by dirtgambit
Ok. so the car goes into 4x4 mode ok, both hubs engage, but when I go back into 2wd, only the right hub disengages, the left hub remains engaged, tried switching the hubs and same effect, must be something with the vac system for disengaging.
- Thank you received: 1999
14 Sep 2025 08:43 #261942
Replied by Lambert on topic 24th August - Noise coming from Jimny 2014 plate
Yeah it's either a blocked pipe or a leak. If you have a hand vacuum pump it should be fairly easy to find where.
14 Sep 2025 09:02 #261943
Replied by mlines on topic 24th August - Noise coming from Jimny 2014 plate
Sound to me like they packed the hub with too much grease when changing the wheel bearing. This then means the hub sticks
Take it off and remove most of the grease to can see, "less is more" is a phrase I would use
- dirtgambit
14 Sep 2025 09:53 #261944
by dirtgambit
I switched the hubs over and the same issue happened, left was still engaged and right was disengaged that's why im thinking the amount of grease might be fine. I did post two images but they are links doesn't look like to much grease, the centre park locks fine when you push it in. cheers
Time to create page: 2.035 seconds
