24th August - Noise coming from Jimny 2014 plate
23 Aug 2025 08:17 - 23 Aug 2025 08:19 #261720 by dirtgambit
Hi, I have a noise coming from my Jimny 2013, its had a lot of work done to it recently the noise appeared after sitting for quite a few months.
doesn't happen sometimes until 5 minutes into a drive, sometimes it happens right away and last week it went a full 15 minutes without happening
The wheel bearings have been changed but that hasn't made a difference, I have a video of it here.
regards
Michael
Last edit: 23 Aug 2025 08:19 by dirtgambit. Reason: add more detail
23 Aug 2025 15:51 #261724 by Lambert
Replied by Lambert on topic Noise coming from Jimny
Propshaft maybe? Rear brake? Certainly road speed related but dunno.
24 Aug 2025 10:47 - 24 Aug 2025 10:49 #261728 by D-Horro
Hey Michael. I assume you had no luck? Still no idea what it is? As I am trying to work out what the noise is as mine does the exact same thing. Even the mechanic who had the vehicle a week can’t work it out. Bought two weeks ago, one day after having and the noise started. Similar to you, intermittent. Can drive 30 mins , various road surfaces, not hear it then the noise starts again. For a few mins. Then I can drive 19 miles home in silence. Appears to be no pattern. So Tuesday 26th Aug,  car is prob going back for a full refund . Yet I was hoping to help the garage out, have them pay for a repair and keep it. But at this rate, I can’t afford to wait and keep it longer, plus being back and forth to the non local garage, is time consuming,  unless someone owning an Jimny actually knows what it could be. And assist? 2014 SUZUKI JIMNY1.3 VVT SZ4 3DR AUTO (43,000 miles)
Last edit: 24 Aug 2025 10:49 by D-Horro.
30 Aug 2025 11:22 - 30 Aug 2025 11:23 #261783 by dirtgambit
Hi, still no luck it passed it mot, I put more camera under the car to find out what it might be, im not a mechanic and usually drive EVs now which I prefer, but in this video below at the 1 minute mark that shaft that's to turn and when it stops turning the noise goes away, its the shaft with the white sticker on it closest to the camera im unsure what's happening or if it should turn like that
Last edit: 30 Aug 2025 11:23 by dirtgambit. Reason: just plain video link
30 Aug 2025 13:01 - 30 Aug 2025 13:03 #261785 by facade
The front propshaft is slowly turning like there is some drag somewhere. If 4WD were engaged it would rotate at the same speed as the back one.
There isn't actually anything to stop it turning in 2WD, except it takes a bit of effort.
I wonder if one of the hubs is engaged.
Try taking the hubs off carefully (undo the 6 bolts around the outsides, they come off with the wheels on and the car on the floor. The splined part in the middle will pull outwards to engage, if one is out and one is in, that could be causing it.
Otherwise, leave the hubs off and go for a short test drive on a clean road (you don't want a dust cloud getting inside the open part of the hub) and see if the noise has gone (and if the front propshaft start to turn again.)
Last edit: 30 Aug 2025 13:03 by facade.
30 Aug 2025 16:55 #261790 by jackonlyjack
I think it's the intermediate prop shaft
I had this sort of noises
It was balancing weight on the prop catching the gear selector frame
I fitted new rear engine mount and replaced the bobbins on gear selector
I use Austin mini poly exhaust bobbins
I would take pictures but it's raining
Time to create page: 0.888 seconds
