2007 JB43 M13A VVT Pinging
03 Jul 2025 08:10 - 03 Jul 2025 08:20 #261113
by Motacilla
Replied by Motacilla on topic 2007 JB43 M13A VVT Pinging
I am going to guess loose spark plug.
(There is only a very very tiny chance this is correct, but if it is, heavens will I look smart.)
In all seriousness, sounds do travel so expect to check all the obvious things -- and then all the non-obvious ones. For example, someone posted last month that they had a sudden top-end tap , which turned out to be not a top-end problem at all, but a failed crank pulley . Assume that the sound is trying to fool you, and clear an afternoon to find it. You will.
Last edit: 03 Jul 2025 08:20 by Motacilla.
- DutchJimny
- Thank you received: 1
03 Jul 2025 08:43 #261114
by DutchJimny
Replied by DutchJimny on topic 2007 JB43 M13A VVT Pinging
It isn't this time, but I've actually had that once before. A friend told me about it too, he had it happen on his m16a grand vitara.
- DutchJimny
03 Jul 2025 09:23 #261116
by DutchJimny
Just removed the valve cover. Everything looks to be in really good order. Replaced the gasket and cleaned the PCV valve while I was at it. Reinstalled it all.
Next I decided to pull the #2 injector plug as I saw some shiny bits on the piston. With the car running on 3 cylinders, the noise was still there and in the same rpm range. Reconnected #2 and pulled the other injector plugs one by one. That also made no diffrence.
- DutchJimny
03 Jul 2025 09:41 #261117
by DutchJimny
Update: The issue has been found! The rubber on the crankshaft pulley is broken.
03 Jul 2025 10:38 #261118
Replied by yakuza on topic 2007 JB43 M13A VVT Pinging
Great thread like a live update!
A new pulley will surely do the trick now, but please revert if it doesn't.
The following user(s) said Thank You: DutchJimny
- DutchJimny
10 Jul 2025 07:43 #261171
by DutchJimny
Yay another update.
The new pulley is in place. Along with new belts and a new front crank seal.
The car is running well, even seems smoother. But that's probably placebo.
The sad part is, I've probably busted my radiator. The fins were already falling out, and now I have a coolant smell. That could possibly be because I poured it all over the top of the radiator. Currently in the process of finding out if it's actually leaking.
Time to create page: 0.171 seconds
