2007 JB43 M13A VVT Pinging
10 Jul 2025 10:58 #261173
by fordem
Replied by fordem on topic 2007 JB43 M13A VVT Pinging
Just replace it - if the fins are falling out you've lost cooling surface area, and run the risk of overheating the engine, and that's the last thing you want to have happen.
12 Jul 2025 07:14 #261196
by Motacilla
A engine with a functioning harmonic balancer will run noticeably more smoothly than one with a failed h.b.
That bit of rubber in the centre of the crank pulley is actively performing a critical function when the engine is running, which is also why that bit of rubber tends to fail. Turning kinetic energy into heat energy thousands of times a minute is hard work.
Replied by Motacilla on topic 2007 JB43 M13A VVT Pinging
The new pulley is in place. [...]
The car is running well, even seems smoother.
