Antifreeze
31 Oct 2025 11:28 - 04 Nov 2025 16:35 #262537
by Paul4A
1999 T registered Jimny. Early G13BB SOHC engine.
Replied by Paul4A on topic Antifreeze
Just contacted my local Suzuki dealer and from our registration number they said:
From your registration we recommend Suzuki Super Long Life Coolant (SLLC) / BLUE - £29.54 For 5L. Your vehicle requires 4.5L.
On a related matter, do you just drain the old by this, what looks like a turn plug on the bottom of the radiator?
Edit, and does that plug just unscrew or is there a knack to getting it out e.g. part turn and pull? I don’t want to risk damaging it or the radiator by being rough with it.
Paul
Paul
Last edit: 04 Nov 2025 16:35 by Paul4A.
- Thank you received: 1992
31 Oct 2025 17:27 #262544
Replied by Lambert on topic Antifreeze
Yeah that's what I used.
25 Nov 2025 10:19 #262901
by Paul4A
Thanks Lambert
Do you know the answer to my second aspect i.e.
25 Nov 2025 13:34 #262907
It unscrews so far but mine was captive.
The following user(s) said Thank You: Paul4A
25 Nov 2025 19:31 #262914
by facade
Replied by facade on topic Antifreeze
It carefully unscrews, make sure that you have a tool that evenly distributes the pressure on the two ears, and do it when it is warm to lessen the risk that the plastic will shatter in the cold. (They never undo with fingers)
I'm fairly sure that I took mine right out and there was an O ring on the end of the white screw that I lubricated with vaseline as I was draining the water every few weeks at one point.
26 Nov 2025 06:51 #262922
That's probably what I felt as the outer restriction, the O ring. As it was draining I didn't need to wind it further.
Time to create page: 0.171 seconds
