Antifreeze
02 Jul 2025 17:51 #261100 by passy
Antifreeze was created by passy
I guess this question has been asked a thousand times before. I have an 02 plate 1300 M13A Jimny. Can I ask what type / brand of antifreeze I should use ( just had the rad off and the whole system has been drained )
02 Jul 2025 18:07 #261102 by Lambert
Replied by Lambert on topic Antifreeze
I just bought my last bottle directly from suzuki. No more money than anywhere else and didn't have to worry about it being right.
02 Jul 2025 18:09 #261103 by Lambert
02 Jul 2025 18:40 #261105 by passy
Replied by passy on topic Antifreeze
Hadn't even thought about going to the main dealer, but as you said would probably be around the same cost.
03 Jul 2025 19:57 #261126 by Busta
Replied by Busta on topic Antifreeze
Jimny's cane with a couple of different types of coolant over the years. That is too say there is no one correct answer. If you have the system drained then you can put in pretty much whatever you want. The only stipulation is that it should be silicate free.
01 Sep 2025 20:03 #261819 by Dan
Replied by Dan on topic Antifreeze
The level on my jb74 always felt a bit low - close to the minimum line, I found a suitable type at euro car parts, Halfords wrongly advised to use comma.
www.eurocarparts.com/p/mpm-antifreeze-lo...entrate-1l-523772452
Time to create page: 0.240 seconds
