Engine not starting
- enforcer69@gmail.com
30 May 2025 20:03 #260663
by enforcer69@gmail.com
Replied by enforcer69@gmail.com on topic Engine not starting
I put the connector from cylinder 1 to cylinder 2, then to cylinder 3 and both injectors are working connected this way.
With test led it shows normal operation to cylinder 1 and 4 and random signal, once or twice then nothing, on cylinders 2 and 3.
Both crankshaft and cameashaft are aligned with marks.
- Thank you received: 1865
30 May 2025 20:17 #260664
Replied by Lambert on topic Engine not starting
I'm going to agree with what others have said about checking the wiring for having been crushed or shorted or some other how damaged.
30 May 2025 20:34 #260665
Yes, it seems to be a signal problem on those two injectors, can be anything from damaged wires to bad contact or damaged ECU...
Is very annoying, I was disconnecting and reconnecting everything with battery disconnected and carefully handled, yet something happened...
31 May 2025 14:30 #260667
Wiring is fine for all 4 injectors
ECU is not giving signal for injectors 2 and 3.
What can cause this? Is very unlikely to get 2 transistors dying simultaneously...
31 May 2025 15:15 #260668
by fordem
Replied by fordem on topic Engine not starting
Have you checked for codes?
31 May 2025 16:11 #260672
Yes, no errors
Time to create page: 0.277 seconds
